Guest lrich
Have been looking at WRC cars specs to try and see how the hell they make so much torque, and then thinking how you could apply this to a street GTR. Easy step #1 (easy, not inexpensive) is go to 3 L from 2.6. This will mean less revs available, but as a street/club day car this is what Im after. The WRC cars have more stroke than bore. I understand this will limit revs, but produce more torque lower in the rev range - due to having a smaller combustion chamber, leading to a better burn efficiency?? WRC cars still only have a realistic compression ratio (8:1 - 10:1) . Having a look at bore/stroke for some cars.....M3 86mm, 90mm - VL turbo 86,85 - RB26 86,73- WRC Focus 84,88. No wonder they reckon M3's have a piston velocity equal to F1!Having read the article in HPI (?) on producing more torque, there are obviously gains to be had in ECU programming, and additional boost controls. Does anyone have any dyno numbers from the few 3 L GTR's? The big track monsters have the big top end turbos, but are there any street cars giving good street performance?
https://www.sau.com.au/forums/topic/15695-more-torque-form-a-gtr/
I would think torque is maximised from the following variables (please correct me if im wrong)
1. Displacement (like you mentioned 2.6-3.0l)
2. Good high compression
3. Correctly sized turbo with smallish compressor a/r
4. What you've just mentioned as well.
5. Anything esle?
I think the most important factor here is getting everything to be correctly matched in terms of airflow.
Regardless, its still amazing how the wrc cars can make 500nm plus from just 2 liters
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
