Hey all,
I'm after some coilpacks for a CA18DET asap. Can pickup in Melbourne or will pay for post.
Could also possibly swap +/- cash for some RB20DET/R32 or CA/S13 parts if you need anything.
Cheers!
Kaz
**If you joined a week/month ago and have no feedback and I can't pickup in person, don't PM me and waste both our time, it's just not going to happen.
https://www.sau.com.au/forums/topic/157160-ca18det-coilpacks/
lol just got 2 replies from you in 1 minute.. did you also have an s12 headlight black plastic surround.. passenger side. How much?
How much for the coilpacks? :laugh:
Also how much/availability for these:
r32 passenger side and centre air vent
drivers side window rain lip for r32 gtst
r32 gtst drivers side indicator
180sx plastic stereo/aircon centre surround
Think that's it :P
Need all of these but coilpacks are most urgent.
hey friend, if kaz180 falls out. i got a set of 4 im willing to let go. email [email protected]
thanks
Thanks for trying to hijack my thread, if I was trying to SELL some coilpacks I'd be a bit annoyed but this is a Wanted To Buy thread so no hard feelings.
Wow You're in California COOL and joined a week or so ago.. how much do you want for them? Whats your bank account & contact details?
Hi sorry for the confustion but i just got a Rb20 and im lookin 2 buy a hks gt2530 63t. thats y i just joined. i do got paypal and here is my email [email protected]. but ill let them go to u for a good price. i got a set of 4. just email and we shall talk numbers. thank
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
