Hi,
If you have read my recent posts here you would know my car is running like crap below boost but runs fine onboost. I took it to MRT today <puts on flame suit> to get my suspension aligned and they did a check on the compression at the same time. They said that I have to get all the coil packs replaced (yes I know that is crap, but I am getting spitfires anyway) and that number 3 cylinder is low on compression. Now I want to know if the car is running OK after replacing the coils, would I nessesarily have to strip the engine down? Surely a small drop in compression on one cylinder is not grounds for a full rebuild. Whats the "braking point" when it comes to compression levels and rebuilds. I mean the car has at least 110000ks on it (if not more) so I know it is wearing out, but it doesnt feel like a car that needs a full rebuild. Is there anything else I can do to keep it running OK without a full rebuild?
Bryce
https://www.sau.com.au/forums/topic/157339-would-you-rebuild/
Hmm.... well I found out number 3 = 80 compression.
Not good...
So am I now making it worse driving it around?????
Also anyone know a good engine builder in Sydney who doesnt charge the earth? I am sure it is just the piston/ring as all other levels are perfectly fine (oil preasure, coolant, temps etc). I am not after a fancy rebuild with forged pistons etc. Close to factory (with say a restrictor plug for the oil added to the head, and an N1 oil pump). How much would I be looking at for labour if I sourced the pistons, rings, oil pump, and restrictor myself?
Not good...
Looks like you done a ringland mate, I think I may know someone that will built it at a reasonable price.
Can you R+R the engine youself?
P.M. if you are keen .
PM sent
Yeah I can probably rip it out with my mechanics help. Its a sad sad day.
Oh well, at least I will have a more relighable engine after this big cost :)
No oil in water or vice versa. No smoke from exhaust other than when gunning it (which my mechanic did to check only!). My mechanic and his boss both think it is a valve or gasket rather than a cylinder. This is good news for me! If it is the head gasket I will put in a Tomei restrictor at the same time. He also said it could be loosing compression to the next cylinder along too. He is going to do a "wet" compression test this weekend and we will take it from there. Thanks for the advice so far people.
A friend of mine got his car rebuilt at Ricol automotive.. Located at mortdale peakhurst sorta area.. Its on norman street...
They do excellent work.. I get my stuff done by them as well..
Just thought i help.. Maybe just give them a ring and get a quote..
Edited by siddr20
Do a leakdown test that will confirm if its topend or bottom.
If it was loosing comp to the next cylinder that cyl should be loosing comp also.
Headgasket is possible and so is valves but I have my money on a ringland ...
Still not sure of the problem, but if I do need to rebuild I will be getting new pistons anyway. Question though. I have heard that forged pistions are better if you boost it up from factory, but I have also heard they are noisy and chew oil when the engine is cold. Is there any alternative or fix for this? Surely there is a way to have high boost but without the problems of forged pistons.
OK we did a full wet test too and it is definately a bottom end problem. The compression picks up when it is hot though. Runs very ruff when cold, but when its warm it seems fine. Oh well I guess I will start looking for rebuilt engines and/or parts. Anyone in Sydney who can help out please let me know. Also I am joining the NSW club right now. :-)
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
