They aren't actually rated by horsepower, they are rated by their flow rate and pressure at which they flow fuel.
040's are rated at 168 litres per hour at a pressure of 5 bar, generally this is good for between 350 - 400 hp, which is why ppl say they are rated at 380hp etc.
still for sale!
Cheers,
Dave
https://www.sau.com.au/forums/topic/157343-bosch-040/#findComment-2922367
Hi, for these to fit into an R32 GTR what modifications (if any) are required. The main reason I ask is that I won't be installing it myself, will get a mechanic to do it, so want to knwo what I am up for in labour.
Cheers,
Dan :sick:
https://www.sau.com.au/forums/topic/157343-bosch-040/#findComment-2922377
not 100% sure what modifications are required as I've never actually put one in, but from what I hear it is pretty straight forward, there should be alot of info if you search for it.
Cheers mate.
I've actually heard these pumps fall in 32's 34's and s15's but 33's is a bit more screwing around... free bump good luck with selling the 4 :D
https://www.sau.com.au/forums/topic/157343-bosch-040/#findComment-2922627
  • 4 weeks later...
$10 dollars to send to anywhere in australia. Guaranteed they are 100% genuine brand new bosch 040 fuel pumps. Bump.
dude you still got the 040 ill like to buy one ill come pick it up today if you can provide me with your contact details or you can call me on 0433188959 cheers
https://www.sau.com.au/forums/topic/157343-bosch-040/#findComment-3015608
PM sent.
Dave.
Edited by Dave32
https://www.sau.com.au/forums/topic/157343-bosch-040/#findComment-3015628
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
