  • Replies 67
Posted Images
HSD HR is OK for street, seems to work well for drift, not sure about circuit. But you can get much much better than HSD, they are a cheap coilover aimed at a price bracket, so they will skimp on things to meet this bracket. Same with all cheap coilovers/shocks.
so which cheapie coilovers do u recommend ?
Thnaks
so is ur car on the road yet ? tell us wat did u done 2 ur engine n wat is the power u making it ?
Thanks
Thnaks
Just dont do it man hey. The bilstein stuff isnt THAT much more, and it will work better, last longer and therefore cost you less in the long run.
Trust me I've been there done that, spent almost $2k on coilover rebuilds, different springs etc etc. If you can do it once properly do it.
BTW, you can get the bilsteins kind of like a coilover. You get the coilover things that go around the shock, then just get the springs to suit. But it would probably cost more than its worth.
I wouldn't recommend any of the cheap coilovers. My experience with HSD wasn't good, but everyone else seems to have good luck with them. When I had them in my car, I hated them.
Each to their own.
had f*kd TEIN, HSD and ISC in my ceffy - HSD were good until i had ISC - noticed even with stiffer spring rate the ISC were much more forgiving with driving on the street - they just seemed to be more adjustable for street, but then work when they needed to on the track.
i havent heard of ISC before. can u tell me which country make them. Also which type of TEIN coilovers did u use ? Thanks
Wat do u think if i get brand new TEIN HA , Cusco, or JIC coilovers ? That shouldnt be a drama right ?
i got Tein HR's in my ceffy and they r bumpy and knockin like hell. Keep the car nice and flat in the corners and when driftin but soon as i hit a bump u can feel the car jump and the wheel chirps as its skips in the air. Soon as i have the cash i will b changing them, unsure to what yet.
If is bumping too much on the street it is bad for the car? my answer will be yes. How about if u changing to the softest on the street ? Are they still keep u riding like a horse ?
4DoorWhore: HSDs look like this
http://www.hsdcoilovers.com/range.html
Most people in aus are running the HRs. They are cheap and seem to work well for the drifters.
Halo_a: They dont make Tein HAs anymore. And most (if not all) of the Jap shocks are arguably inferior to European shocks. But if it makes you happier, get the cheapest nastiest set of coilovers you can find. After all, the more expensive stuff isn't like that for a reason is it?
Thanks
not on the road yet had a few dramas building engine next time i'm home then got g/b and diff to finnish then its on the road again
I personally would find the extra $200/300 or whatever it is and get the bilsteins. But thats my oppinion.
For the sort of money those coilovers are worth brand new, you can get the Bilsteins made into coilovers. $2262 they cost me and use your own factory strut tops. If you've got a set of coilover tops around (suit rectangular coil) then you can take another $100 off the price. This includes custom spring rates (Eibachs, best springs in the world) AND revalved to suit.
I see some sponsors doin Tein flex for $2050 and Tein monoflex for $2450
For the normal strut and spring combination it comes to $1436 for the set delivered.
EDIT: of Bilsteins ^^^
Edited by salad
Wat i knw is TEIN doesnt make in Japan anyone more they make in Taiwan. If so i might get bilsteins or ohlins coilovers. wat the the average price on them ? IS there any manufacturer in Australia ?
Thanks
The cheap Teins are made elsewhere, but the more expensive ones are still made in Japan, which ones though, I dont know.
Bilstiens and Ohlins aren't exactly cheap, your best bet would be the groupbuy that SK is running. Prices for R32 are quoted above. Ohlins are damn expensive and I somehow doubt you could afford them if you were considering HSD.
Bilsteins are all made in Germany. I'm fairly sure all the Ohlins are made in Sweeden, but I'm not certain.
Have u been on track with the Bilsteins coilovers ? Are they good for drift ?
If i get the bilsteins coilovers wat else do i have change the foot work area ?
Thanks
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
