Hello, fellow SAU members.
Couple of items for sale.
Prices do not include postage.
Item: Aerpro 4channel Amp wiring kit
4 Channel Amp Installation Wiring Kit, 8GA PWR, 600 Watt -
- 6M 8GA Red Power Cable
- 1.2M 8GA Black Ground Cable
- 6M 16GA Blue Trigger Cable
- 2 x 6 metre Twisted Pair RCA Leads with Right Angled Plugs on one end
- 6M 12GA Speaker Cable
- inline AGU Fuse Holder wirh 60 Amp AGU Fuse
- 2 x 8GA Ring Terminals
- 2 x 8GA Spade Terminals
- 4 x 12GA Spade Terminals
- 2 x 12GA Butt Connectors
- 1 x 8GA Butt Connector
- 2 Self Tapping Screws for Fuse Holder
- 1 Ground Screw
- packed in hang sell, full colour blister
Reason of sale:
I needed a 4gauge Power Amp wiring kit.
The Wiring kit is brand new and not used! Only opened to inspect contents. Was purchased from Repco.
Price: SOLD
Item: 4GB MP4 Player
* Durable colored aluminum metal case stylish body design
* 4GB Samsung flash memory
* 1.5 inch 65536 true color OLED screen
* ID3 tag Support: Lyric display allows Karaoke
* With E-book and Telephone book function
* Support MP3, WMA, WMV, ASF, WAV, ASF, ACT formats
* Convert WMV, MPG, MPEG I, MPEG II and AVI to new Advanced MTV format by included software
* Covert JPEG, GIF, SWF picture files to PIC files to be viewed by Advanced MTV by included software
* Built-in clock
* Built-in Picture Viewer
* Built-in microphone for digital voice recording
* Built-in FM Radio (Tuner 87MHz - 108MHz), allow to pre-set radio stations
* Support file folder management
* Battery: Lithium-ion Rechargeable battery (Build-in & recharge by charger or USB port)
* 2 Replay Mode: Manual Replay, Auto Replay
* 4 Record Mode: Long VOR, Fine VOR, Long Rec, Fine Rec
* 7 Play Modes: Normal, Repeat One, Repeat all, Folder, Repeat Folder, Random, Intro
* 7 Preset EQ: Normal, Rock, Pop, Classic, Soft, Jazz, DBB
* 15 languages support: English / French / German / Italian / Spanish / Portuguese / Swedish / Czech / Dutch / Danmark / Polish / Russian / Korean / Japanese / Chinese
Reason for sale:
Wanting to purchase an Ipod. Have had some issues with it detecting songs, thats what you get with ebay china items :D
Had item for a couple of weeks and decided to upgrade to ipod as headunit has ipod connectivity.
Price: SOLD
item: HP Jornada 568 PDA + GPS Mouse
- Nifty PDA, had a NES,SNES,gameboy emulator running. Winamp running on it and also TV remote software via the built-in infrared.
- A couple of light scratches on the exterior.
- Whole touchscreen works on LCD with no dead pixels and bright screen.
included is;
Polstar GPS mouse
Along with a USB cable to plug PDA to pc, car charger and a leatherish case
Will provide gps software.
GPS software needs a CF memory card to store maps. (not included)
Reason for sale:
- Dont need a gps system in my car, just collecting dust.
- PDA+GPS must be powered via cig lighter during gps operation
Example of wiring to operate:
- The PDA may lag depending on GPS software you install.
- Saving towards an Ipod
Price: $200
I think thats all ive got to sell for now :P
PM/reply for any questions
Cheers
- Patrick
  • 4 weeks later...
  • 1 month later...
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
