not quite sure wat u mean
i dont see how you would starve the car with a 040
wat mod you supporting
as long you getit installed right
pfc, , cooler, bigger turbz, stock injectors, full exhaust
yea i know i was told even if you install it right i'd need a ( surge tank?) cause ill run out of petrol soon as it gets in the reserve tank.
ps= i like ur car man :)
Edited by R33GOD
thanks man
umm yer surge tank is always a good thing make sure that when it comes to fuel you dont go cheap always go for the big bangers to much fuel is better than no fuel at all
im running a 044 with a 1.5 lt surge tank and a standard lift pump and that suppourst 300 rwkw
also make sure you get some teflon braided hose if you buy any one those big pumps or else you will ahve trouble after trouble
there is a thing as a fuel pump thats too big
if it can pump too much and if your sitting in peak hour traffic idling lots the pump will keep going and pushing the fuel around the rail system and back to the tank, which will heat up the fuel, giving you a soggy and sluggish response when you open the throttle
before i go tmy inj n ect i had standard ones and a 044 with a malpassi i was stupid n tryed to get as much power as possiable without any mods
anyways
the malpassi seem to over run the inj and pump a heap of fuel into the car but max sure they dont max out or else Bang..
but you should be right for say 240 rwkw max
everything is so complicated these days lol (only if you make it complicated)
what sort of pump is ideal for an r33 if not the 040?
thats very tru but i wat i was getting at was better to more than none at all cause you know wat a shortage of fuel does
040 is fine for most mild gts's
gtr is another goody (but usually 2nd hand, older)
its only like really big pumps that have the "too big" issue
like maybe an 044 or twin 044's etc
the best option if you are chasing just a lil more power with a good tune would b a walbro pump in tank direct replacment just make sure it aint a ebay on i got one of those a long tome ago lasted a 2 power runs
ive already bought the bosch one :spank:
I got a walbro with 3/4 tank syndrom. gonna aget it down further tonight, anyone know how? is it just the way I placed it back into the tank that it didnt drop down low enuff or somehting?
thast k i have a malpassi if you like but you would have to take it to a tuner if you have one cause they are fiddle lil pricks you should be able to make 220 with those mods already just get a sureg tank put your lift pump in
done
with my walbro back in the day i made a extension with some good hose with the filter at the end she sat right at teh bottom easy as
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
