I am wanting to upgrade the whole setup and what some ideas.
I have adjustable coil overs all round with adjustable hight etc
Rear
traction rods
adjustable upper control arms
Hi cas bar
strut brace
lower tie rod brace
whitline adjustale sway bar
ajdustable tie rods
Front
Strut brace
whit line adjustable sway bar
Heavy Duty steering rack tie rod set
Cusco Front Tension Rod bar
Upper Camber Arms
Pillow Ball Adjustable Tension Rods
Adjustable Castor Rods
pineapples
I am wonder if you have some ideas or some past experiance. That you can direct me where i am wrong.
I will be buying the bits and peices and installing them myself and then gettin them adjusted and alined after.
What do ya think?
Edited by mahartika
https://www.sau.com.au/forums/topic/158326-suspension-set-up/
Rear
traction rods - not necessary
adjustable upper control arms - just get some offset bushes instead.
Hi cas bar - lock bar presumably - good idea.
strut brace - not necessary
lower tie rod brace - not necessary
whitline adjustale sway bar - good idea.
ajdustable tie rods - what for?
Front
Strut brace - ok for some bling.
whit line adjustable sway bar - good idea set it upp on soft.
Heavy Duty steering rack tie rod set - not necessary
Cusco Front Tension Rod bar- not necessary
Upper Camber Arms - would get some bushes instead.
Pillow Ball Adjustable Tension Rods - Cusco do some nice ones.
Adjustable Castor Rods - um, see above.
pineapples - go on the back!
What do ya think? You don't actually need half of this stuff - so you can save a heap of money.
Front strut brace is worth while.
Aside from that, I agree with everything djr81 has said. A lot of those mods seem to be the typical drift mods.
With the rear tie rod brace, you'll actually find that it's a toe arm brace and it's designed for non hicas models.
If you have a hicas model car, you dont need toe arm brace or adjustble toe arms, you already have a solid brace there and the stock tie rods have plenty of adjustment
And the pinepples are a worthwhile investment too
I am aiming for a bullet proof setup with adjustment of every aspect so i can tune it for curcits.
The guys have pretty well covered it, the only thing I would add is having adjustable everything is fine, as long as you know what each adjustment does. As long as you know which adjustment/adjustments to make to fix the handling imbalance that you have on the day.
An example, it's understeering mid corner, what are you going to adjust? Front stabiliser bar? Rear stabiliser bar? Front damper setting? Rear damper setting? Front camber? etc etc
As the saying goes, "sometimes less is more". If you have so much to think about and choose from, then there is more chance that you will choose the wrong one. Plus you will spend so much time worrying about the adjustments, time that would be better spent learning how to drive faster, watching others and learning the fast way around the track.
What I say to guys, often, is that race cars all the way to F1 have driver adjustable stabiliser bars, because
they are the most effective and simple way to change the car's balance. That's the first place I suggest everyone starts at, it's easy, quick and you can feel the results instantly. The last place is adjustable damping, because it is complex and many people can't determine which direction to go in. When we get a new driver in the race team it takes me a full day of training to get them accustomed to the feel of course damper changes. It takes a full season until they have a good feel for fine damper changes, some never get it and us engineers have to guess what the car needs.
Some things for you to think about
:rofl: cheers :)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
