carmate.com or from wreckers jap wreckers
had a looking at carmate couldnt find it and alot of ppl have had issues with them. which wreckers in perth do you think i should try?
ps. using mates account to reply(only realised after)
https://www.sau.com.au/forums/topic/158374-r33-side-skirts/#findComment-2941299
if you are in perth and are lookin for some skirts i do believe there is a bloke selling pretty much his whole car and he has stock ones (m-spec) i think and also 400r, it is in the For sale section in WA under parts and acc think title is like r33 parts.
But yer same goes for all if you think that car mate will give you a crappy part just check for sale section seen alot of skirts in there recently. Also wreckers would be good Try C-red i hear they could have some.
https://www.sau.com.au/forums/topic/158374-r33-side-skirts/#findComment-2941812
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
