Photos that i took will be up soon, Apart from that very good event just getting better as we go, And great idea the fish n chips at that bar too. Some of us will sit down and organise an even better one to come. Cheers guys for those that went.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
