Hey all - finally my first topic on SAU *bleeds*
Doing a conversion to my brothers ceffy at the moment and it would seem that the rubber pipe that goes to the front of the turbo wants to run directly into the rear power steering line
anyone else had this problem??
could someone take a pic of that front pipe and the ps lines from the pump for me?
also what is the -easiest- way of connecting the engine loom to the dash loom?
do most people use the de loom and change the plugs, or change the plugs at the dash end of the 32 loom so they fit
thanks,
tony
Edited by TonyL
https://www.sau.com.au/forums/topic/159168-a31-power-steering-picture-needed/
  • 1 month later...
thanks,
tony
no idea about the power steering line
did this conversion on my cefiro not long ago. used the det engine loom and the de starter motor/positive loom. if the car is going from auto to manual you will have to short the auto switch at the fuse box, bottom plug. hope this helps
Edited by SMiTHBRo
cars all finished now
I rewired the dash plugs on the DET loom to suit the 31 dash - most people would just chop and join only a few wires to make the car run -- but I'm picky and wanted to make sure as much was connected as possible
For the power steering my brother extended the drain hose from the reservoir to the pump with some spare pipe and tubing we had. And I think we undid the stopper on the rear high pressure hose on the pump and swiveled it around slightly.
excel spreadsheet with my plug findings
Edited by TonyL
other suggestions would be a solid intake pipe (as its less diameter then the rubber one)
or converting to another power steer setup
the a31 DE setup is different to the r32 as the 32 high pressure hoses to the pump BOTH go to the pump from in between the radiator and pump
so you performed a DE+T??
that;s what i'm doing,
what i think i'm going to do is just replace the hose, it's not broken but it is 18 years old so i will just replace it and get it lengthened so it can be put out of the way of the intake pipe, then swivel the stopper around
i know i could lengthen it myself but it's all high pressure hose so probably best i leave enzed to do that kind of thing, as i'm REALLY anal about that things like that.
is that a good idea you think tony?
easiest yes best not necassarilly, you'd be surprised how simple this conversion is, and how effective it is
a lot of people complain about the lack of low end power the rb20det has,
with this combination i now have an rb20de high compression cylinder engine with the turbo,
i'm only running low boost so it won't go bang, even in the event it does then i will simply put in R32 rb20.... but i'll probably build an rb30det in the event of engine blowing up
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
