I have for sale my used set of TEIN HA Coilovers. They were used in my S13 Silvia and suit this type of car, 180sx, A31 Cefiro & C33 Laurel.
Have just upgraded suspension so these are no longer required...
Height and camber adjustable as well as rear dampener and height adjustment. Come with HKS camber tops!
Camber top ball joints are firm with no play or rattles and no sign of leakage in the shaft region.
Spring rates 8 Front, 6 Rear.
These are also unique in the fact that they allow for at least another negative 2 degrees of camber to be run at the fronts as drilled from Tein factory in Japan.
Fronts were rebuilt by Jaustech here in Adelaide roughly 10,000 km's ago and coilovers have been used with no complaints in my car for no more than 20,000 km's.
Interstate postage not a problem, and for cheap!
A MUST for drift and an essential mod for any serious enthusiast! One of the first mods you should consider...
EXCELLENT condition; just a little dusty in the picture...
$900
PM with any questions.
Edited by driftKNG
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
