Hi,
I have now lowered the price as i need the money for my daughters birthday in 2 weeks..$SOLD - Pending payment
I have a turbo for sale that I got for my 21st birthday. Ive had this turbo sitting around for a while though I no longer require it as I have a gt30.
Details of Turbo and History.
The turbo started off as HKS TO4e. T3 style, will bolt onto standard manifold.(Rb20 + Rb25)
It was rebuilt due to sus bearings.
360degree bearings were put in and hi-flowed and new front compressor wheel.
The rear t4 .42 housing was changed due to its tiny nature and its ability to make no power. The HKS wheel in the housing was enormous, huge so it was left in. Put in its place was a garret .63 rear housing with major machine work to have the HKS wheel fitted. A V-Band style flange was also made for it at this stage wth an adapter plate to go.
Since the rebuild this turbo went from home to tuner and back and then to WSID and thats it. The rb20det it was one had manifold + cams and ran out of puff a little up top. A bigger turbo was chosen and this one given to me, this turbo is off lengend01 's car on these forums. The car ran 12.2@111mph with this turbo.
It also made 242RWKW@21-22PSI
post-28122-1173174031.jpg post-28122-1173174005.jpg post-28122-1173173980.jpg post-28122-1173173955.jpg
post-28122-1173173929.jpg post-28122-1173174066.jpg post-28122-1173174093.jpg post-28122-1173174131.jpg
NOTE: These dyno graphs show the 238rwkw figure, though not much difference. And also in one pic comes as part of the v-band clamp on the end is the adapter for when you get the dump made..
To put things into perspective about $3500 was spent on this turbo, as the builder promised easily 500hp from it or more.
$640 reasonable offers welcomed.
Note: For anyone trying to ruin the sale by making insulting offers or useless statements please pm me, and not post it on the thread for everyone to see, thank you.
In sydneys west
Reply via PM
Edited by MZTRBO
Also for those not sure what a V-Band is, its basically a clamp that can easily be undone when you want to take the turbo off and on, so not unbolting and tightening it back up.
It is suppose to have a better seal than a normal bolt on dump also...
Cheers
What trim was it? 40, 46, 50, 54, 57, 60? I Noticed the compressor cover has an AR .50 stamped on it, possibly a 50 trim to start with?
By 'Hi-Flow' what do you mean? Debured and smothed? or has it been ported? How heavily? and has this porting been done on a flow bench or 'by feel?'
Also can you supply some of the following trim sizes:
Compressor inlet pipe
compressor outlet pipe
Compressor inducer
Compressor exducer
Turbine wheel outlet
Turbine inducer
Turbine exducer
I have a very keen associate, although we need to confirm that this turbo will suit the intended application.
Cheers
Mate, as stated I got this as a present so this is all I know..
By hi-flow the inlet was enlarged. Dynatorque in sydneys west rebuilt it and they sent it to garret to be flowed, I know this for sure.
As for the sizes, I have no idea except for the sizes already mentioned. thats why I have tried to provide as many details as possible. + graph.\
Hence the cheap price!
If i cann help you any further let me know. I also do not have a graph on photo with rpm. As for lag the car had full boost for about 2300rpm on an rb20det and would drop off power at the end,, now i dont know if this was the turbo or the stock set-up causing it, but when a gt3040R was put on it had a similar effect at the end???
The car ran 12.2 and once boost started it seemed to finish straight away as you would pull another gear.
Cheers
Cheers
I wouldnt get it if you are interested in minimal lag as it has some, though for drag use it would be optimal as I would run an easy 11 with it on my rb25...which was its intended use. only reason for sale to is that I purchased a gt3040 off a good mate, at mates rates and I am aiming for 280rwkw which tis turbo would be stretched to do with the set-up i planned to run..which is stock everything..
Cheers
Note: 11sec thing...its an rb25 in a r32..Cheers
Edited by MZTRBO
vsute, the whole s where the nipple goes..
Yes will bolt on same flange as standard turbo, t3 style.
Phantom32, I was also going to put it on my rb25 for drift purposes..Lag would be less then a rb20. I would say start building boost from 2300rpm and full boost by 4200-4400rpm...I was going to work around the lag when using it for drift its not to dificult (if your talking lag as in when it hits full boost, or lag when its on full boost and how quickly it is spinning eg, how quick it revs out.)
In the wet, I wouldnt give it in the wet, but normal driving you wouldnt have a problem..
The rear wheel is a steel big HKS item good for 30psi atleast Id say..
Cheers Daniel..
PS. wow 27 pms and no sale yet????
1jzdrft....I just stated that its for my daughters birthday and you offer me 300dollars under what I asked.. wat a joke mate? I better take back all offers considered cause that was insulting. 1jzdrft dont message me again, unless you want my rb25 series 2 turbo for that much.
Daniel
Edited by MZTRBO
y do ppl not put numbers up if they selling somethin ?
would this be a straigt bolt onto a rb25det neo ! + external gate or do i need to build vband dump pipe? and any other things
plz gimme a call 0423532992
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
