Hi there people,
The oppertunity to buy a house and get a cheaper car has come. I have owned my cefiro for just over a year now and its the best car i have ever driven.
So here goes:
Nissan Cefiro 1990 model
124 XXX on the car
Gunmetal grey
Full Autech bodykit
Up date grill and tail lights
series 2 RB25 roughly 60 thou kms
Manual 5 speed
Aftermarket clutch
Power fc + hand controller
Apexi boost guage
Hks pod
R 32 GTR front mount Intercooler
Bosch 040 fuel pump
R32 GTR brakes and 5 stud conversion
R32 gtst rims
Cusco castor rods
Unknown 2 way mech. diff or locker
Tein HR coilovers. Spring rates unknown
HKS camber tops
Cusco rear strut brace
3' dump pipe
3' exhaust with metal cat
Nardi sports steering wheel
Pioneer Deck with ipod addaptor
Some random jap speakers in the front doors
This is all i can remember at the moment but im sure i have forgot a few things here and there. Car made 170rwkws on stock boost when last tuned. It hasent been boosted because i needed to upgrade pumps but it has been replaced now and needs to be tuned again. Tuner estimated roughly 220rwkw's. Car is fun to drive in the hills and also slides awesome. This cefiro is amazingly clean and it would be hard to find another in such mint condition.
The car has been engineered in Adelaide for the engine conversion, gtr brakes, 5 stud conversion, lower ride height and exhaust system. I have all the papers including the import papers from when the car was brought to Australia from japan.
I am asking $14500 o.n.o you cant get 1990 model cefiros into Aus that easy anymore and it is an amazing car.
The car is located in Adelaide.
Ph: 0422 610 771
cheers
Josh
Edited by yoshiE
https://www.sau.com.au/forums/topic/160128-nissan-cefiro/
  • 5 weeks later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
