One thing I haven't figured out yet is the knock reading on the SAFC2...
The reading kept telling me 0, so I got into:
settings -> Knk level
and set the knock levels for 1650 and 3650 rpm to whatever they were at the time (45 I think??)
Anyhow, if I stay on that screen, as the car warms up the knock reading goes to about 100. If I go to one of the screens in the monitor section, the knock goes up to about 10 on idle, and down between 0 and 3 when driving...
Can someone tell me what the differences are? I have no idea what either mean now :D
Thanks
George
https://www.sau.com.au/forums/topic/16020-safc2-knock-readout/
The knock readout (if it is the same as the PowerFC reading) is a synthetic indicator of engine 'health'.
A bad engine is 60+
Mine came to 11-12 avg.
A new engine is supposed to be 20.
A well run in good running engine is 10.
30 - 40 might be a more well worn motor.
As it gets higher, the 'worse' condition the engine is (ie. the more likely you need a rebuild or the more it 'pings' metaphorically speaking).
Funny thing is that an engine that has forged internals will put out worser numbers.
This is a reading that the ECU (in its limited intelligence) gives. It is not 100% reliable.
T.
But that still doesn't answer my question...
See the SAFC has a number that it spits out in:
ans another on the monitors. The one on the monitors is relative to the one found in settings....
For example when I start the car cold, the reading is 40 (in settings), so I set the knock levels for 1650 and 3650 (that's all it lets you set) to 40.
Then, as the car warms, the number it shows for the current rmp grows to about 100, sometimes more.
The munber in the monitor section, is always around 20 on idle (when the car fully warms up), and about 9 when driving....
I dont know what the difference is between the 2.....
Does any1 know?????
DJ_L3THAL: I have attached a pic of the ecu as you look at it mounted in the side panel. the light blue (23) and light green(24) are the wires for the knock sensors. Connect it to 24 (cylinders 4-6) as I have read that they lean out first.....
Think about this - does your engine run the same in every environment?
Run a bad load of fuel - the engine will run bad = higher knock number.
Run it on a cold morning and the motor rattles due to the cold = higher knock number.
If I warm the car up, kill the motor, reset the knock - the rating is like 1-5 which is almost unbelieveable.
T.
All this I understand, but it does not explain the correlation between the 2 different readouts for knock...
The one in the setting menu, hangs around the 100 mark when idling, and increases as rev it out.
The one in the monitor section peaks at 20 on idle, and drops to 9 as I rev it out..
Which figure do I go by?
Yeah, thats what I am thinking (otherwise why would it be in the monitor section)
But obvioulsy it has some correlation with the values that can be set in the settings section. I wonder how this value would differ if the the setting were changed?
So then.... what should the two knock values for 1650rpm and 3650 rpm set to????
I got a SAFC II hooked up to my S14 SR20DET. I reckon the knock readout is completely haywire. The best way to check it is to go to the "sensor chk" and get a direct reading. I get around 50 when idling and it goes higher as revs rise/engine warms up.
I reckon the readout is complete shit as I can floor it at 3500 rpm or 2500 where knock would occur and it stays exactly the same, not even 1 unit count higher. Then I unplugged the det. sensor, and put a resistor on the harness and left it. And guess what. The readings were the same! WTF? How can it even get any readings if its not even hooked up? Sometimes it would show a value of 50 and then I swtich the car off. And it drops to 45. It should go to zero cos the engine is OFF!!
I cant figure it out either, so I disregard the knock sensor input. Hey btw, do you sometimes get trouble switching between File 1 and 2? I sometimes find switching between them CLEARS all my settings!!!!!!! Pisses me off.. Blah =(
The 2 maps/knock sensor reading is the reason i got the II over the original SAFC =(
Nah, I haven't tuned the second file, so I haven't tried switching...
I might this weekend though, as I finally booked it in for a dyno tune...
Yeah that knock sensor readind pisses me of. It makes no sense.....
Did you figure out what the relationship is between the readind in the monitor section, and the reading in sensor chk?
I did 4 years of engineering maths at uni, and I cant figure the prick out!!!!
Go here to get the knock function working, but as I said before, its about as reliable as dogshit!!
http://www.prostreetonline.com/pso/pages/h....asp?sessionId=
Sensor Chk is the raw reading of the knock level. What you see during monitoring is any knock value that is HIGHER than what has been set in Knk Level. Ie so if the raw reading is 60 from the sensor, and the Knk Level been set to 50 (as background noise at that particular rpm), it'll report 10 to you!!
Read the link and it hopefully will clarify things. But still, i reckon the whole knock feature doesnt work. Might work properly with a separate knock unit from Apexi.
Let me know about switching maps too. Even just make two different files and switch between them while the car is off..
I have a similar thing on mine but much lower numbers.
Mine gets to about 10 on idle and reduces to 0-2 during driving. Is this indicative of a good engine (TOnyGTst?) or incorrect settings due to low numbers. I followed the instructions on that web page posted three times now with similar results.
Hey Busky, thanks for the link.
OK, I am a little less confised, but I still don't fully undersatnd it.... I can't be bothered with it anymore though.
I dont think that it tells you what lever you have gone over the raw reading....
For example, my "acceptable" levers for the 2 rpm ranges specified are: 42 and 47 respectively. Sometimes the raw value has gone up to 130 when driving for more than 1 hour, but the readout in the monitor section is still only 9.
47 + 9 = 56 so that cant be right.
I guess we just stay tuned to that site for the next update...
The knock sensor is handy.
It learns the 0 point by the average of the two rpm ranges. The figures given are then taken as 'knock level' in the monitor section.
If done right the level of knock will stay around 0 for idle and low throttle, as this has been zero'd.
I have mine set such that I can use it in the 'graph mode' against rpm etc.
I find that a knock level upwards of 70 will correspond to a very light ping that gets worse, upto 190+ for a substancial ping. Setting the fuel and timing to a level where a max of 20ish is reached at the peak is what I aim at.
So what have you set the knock level to be in those rpm ranges? Depending on what these are, it determines the value in the monitor section like you say.
For example, when I fist did it, the car was warm, and so those 2 values it bases the average on were 70 and 90 respectively. From that, my knock readout in the monitor was never over 7 on idle, and dropped to 1 when cruising / WOT.
Now I set them again when it was cold and they are in the low 40's, so I peak at 19 / 20 on idle, and drop to 7 - 9 on WOT.
How is everyone else's setup?
But that is what confuses me now....
If you take these readings while the engine is warm, your car could be knocking like crazy, but you set these knock levels at that time. Then in the monitor section, as that reading is relative the level you have adjusted, it would still show a low figure!?!?!?!?
So the knock level shown in the monitor section, is only relative to: how bad your car was knocking at the time you set it.
So how does this figure give you a true indication of knock? This was my argument to begin with....
It's giving me lots of headaches... I'm the type of person that doesn't just accept things, I need to know how it all works... :)
LOL told you man, its not reliable at all!!
I wound the timing way back as an experiment and it still showed knocking. WTF? And as i said b4, I disconnected the knock sensor once and it still said i was knocking.. heh.
I'd just leave the settings at 70/90. Just when u boost it, make sure it doesnt go >150 (over the noise value) or some high figure like that!! Usually the ECU will wind back the timing if it senses knock anyway, so usually fat knocking wont occur in the first place unless the ECU cannot retard the timing any more. The SAFC might be confusing knock for engine noise at high RPM..
Im gonna take a look at Link's KnockLink. Looks good!!
a 'knock engine' as used to test RON figures for fuels will set you back the best part of $200k if you want an 'accurate' figure for knock. I'd suggest that the factory ecu does not allow the engine to "knock like crazy" under any circumstance (given factory timing and appropriate fuel). If your engine is 'knocking like crazy' expect it to die pretty soon.
The 'relative figure' as used by the factory ecu is good enough to tune with. Mine is fairly predictable and has served well as a tuning guide. The knock is best looked at on the graph trace Vs rpm and fuel correction. This way you can determine the relative 'stress point' of the engine's power band under load and adjust timing and fuel to suit.
I can quite easily remove any knock by decrease to timing and increase to fuel, the problem is in finding the balance for power.
    • Lucky the prp block is supposed to be released next weekend
    • Wow guys thank you very much for the HUGE info :-) @GTSBoy I have like 30 minutes if test drive with that car/engine and it not stalled once. IMO it ran very smooth so i guess it was not that bad(but asi i said it is stock) That atmo BoV is worse than no BoV or in my case or it is/will be the same? Cuz frankly i rather have little whooosh sound than that sututu 馃槃 But either way the less harmfull for engine/turbo the better(if the stock is not an option right away) Yeah about that rebuild i talk with guy who will be doing swap and custom pipes...i think i can get stock BoV or get aftermarket which will function the same. Yeah i looked at that R35 option and i try ask my mechanic more about that if he knows. The engine has stock ECU but i can get Nistune for it. On that stock it runs quite well...but i have limited time with it so rly dont know. Ecumaster is this https://www.ecumaster.com/  It is not some dodgy backyard ECU :-)  @MBS206 Yeah but it will be better to have Nistune than the completely stock ECU no? About that "same" atmo/no BoV. The drivebility would be the same? I dont know but i kinda guess that amto BoV would cause more problems than no BoV in my case? Or is the same? You just "change" one sound for the other? Yeah i read many many many topic about hurting the turbo. But no one know anybody that would 100% tell that his turbo/engine blows/get damaged by not running BoV. Of course turbo would be little happier IMO if it has BoV ..but if you do not trash i think i should be good. And as you can see iam already trying to get this right...just working what i have right now :-) Yeah iam kinda the same...i dont want nothing loud and frankly iam not liking that sututu noise that much 馃槃 i rather have little bit of "whooosh" or no sound at all. Of course in my case it si a completely another world when you came tu Turbo car with open air box and no BoV and you driving the N/A ...all i hear is engine. Here? I heard turbo/sucking and that sututu 馃槃 @Yeetus So in my case it is really no difference to run no BoV or some atmo BoV like GReddy FV2? The car would drive the same and has "the same" little problems? As i wrote above i kinda thinked that atmo BoV with stock MAF would cause more problems...but then again i dont know much about no BoV either :-)  So to avoid stalling i "cant" just put neutral on stop lights like from higher rpm? Or? Yeah iam already looking for ECU :-)  Yes iam at the same side with thar R35 MAF :-)  @Dose Pipe Sutututu Thank you i (my mechanic/tuner) will look into that) Guess iam taking the Nistune at least :-)
    • Here's the workaround with Nistune I was talking about, just add in more timing on the decel table And play around with the fuel cut & recovery, it's enough to stop it from stalling on a decel
    • Hi Apex and welcome!
    • Probably too late to reply to this, but worth a try. It's not calliper flex, the calliper as a whole is moving so it has to be calliper mounting bracket flex.  Calliper mounting brackets are designed to stop the calliper rotating, they don't need to be designed heavy duty to stop the calliper moving in and out.  Whatever it is is not the major cause of poor pedal feel, the outer pistons are moving towards the disc rotor the same amount as the inner pistons are moving away from the disc rotor.  Hence no change in fluid usage, what extra fluid is needed to move the outer pistons is recovered from the inner pistons. For a calliper to move as a whole by far the most common reason is the rotor is not perfectly centred in the calliper.  The first thing I check is that hub face is perfectly clean, bare metal, where the rotor hats contacts it.  Then I check the that rotor is firmly held in place by at least 3 wheel nuts (or equivalent). If all of the above are confirmed to be in perfect alignment then I would check the piston sizes and ensure that the 3 inner pistons and 3 outer pistons have matching diameters (eg; 28/32/36mm).  I have seen a no name 4 spot calliper that had 1 of the 4 pistons a different diameter. Maybe I missed it, are both the callipers exhibiting the same problem? I would remove the transfer pipe and inspect it to make sure that there are no restrictions. Maybe you already have but if not I would return them with the video and have them confirm all of the above.   Hope that helps Cheers Gary
