well i tried removing my o2 sensor the other day, it has come off 6 months ago when i changed dump pipes..
after my efforts the other day my ecutalk is telling me the o2 sensor is really really farked now, not just farked.... o2 is reading between .00v to .99v at idle... car is running like total crap and conks out when left for 1min or so...
now that i know its totally farked, reckon i just bash the top off it with a hammer and undo the bottom part with a socket set? have to get it off, and ive got a replacement here...
ive unplugged it and its running .30v which is cold start now so it will run rich as....
any opinions or ideas?
thanks all
Ed
https://www.sau.com.au/forums/topic/160243-o2-sensor/
ive tried just about everything else, when we got it out of the old dump it was put in a vice and a spanner and breaker bar was used!
this is looking like the only way, used a spanner, breaker and hammer in my driveway but couldnt get it off!
smashy smashy time!
https://www.sau.com.au/forums/topic/160243-o2-sensor/#findComment-2975468
Yikes!
Get some innox or some kind of rust-easing spray onto it overnight. Then give the ol' spanner another try.
OR... if you don't care about the old one, the bashing the top off to get a socket on will probably work too... if you get more leverage on the ratchet than you do the spanner.
https://www.sau.com.au/forums/topic/160243-o2-sensor/#findComment-2975609
wd40ed it over night, still no luck
i think when i was attempting removal the other day and hitting the spanner with the hammer its farked up the insides even more
dont care about it, do guna smash it goooood
https://www.sau.com.au/forums/topic/160243-o2-sensor/#findComment-2975634
UPDATE
the right size spanner, some wog power and juggernaut power we managed to get it off without breaking it
pitty i wanted to smash something....
new sensor is in and reading alot more smoothly, although there are still some variations in the voltage i think thats because its running rich due to the tune...
https://www.sau.com.au/forums/topic/160243-o2-sensor/#findComment-2975817
    • Found the answer: it wont fit without a bit of work- you'd have to change the guards as well
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
