Did an oil change today and used motul due to it being more readily available here than my regular drop.
Whilst at repco I saw an all synthetic from penrite called SIN. Has anybody had any experience with it. Going by the price it would want to be some good schizzz.
https://www.sau.com.au/forums/topic/160255-penrite-sin/
Its the one I was telling you about. 5w60 >_<
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975671
My mechanic would agree with that! He thinks using any penrite product is a sin!!!
HAW HAW HAW!!!
A mechanic I know would say anyhing else is a sin! >_<
He has been trying to blow up his 200 000km stock bottom ended 350awkw GTR for years and cant...he attributes some of his lack of success to this oil!
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975700
I used to use Penrite in my first 33....I liked it and it was recommended by quite a few workshops...I reckon this stuff would be pretty good..they seem to know what they're doing...I used Motul in my other cars though...and also found that to be reasonably good.
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975710
yep, penrite has had some good history on its side. A few racing cars and been making oil for donkey's years etc....
Tried motul and switched, I've been using the royal purple and really happy with that. Great oil temp and pressure stability, good friction resistant and seems to come upto pressure quicker (than the motul i was using prior). On the skyline I think the royal purple has the history and the creds- especially with hi end gtr's etc. A lot of top jap workshops have used the royal in the past.
That's my pref, for what its worth...
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975820
A mechanic I know would say anyhing else is a sin! :laugh:
Haha, I think most of the top end oils in fairly stock cars (ie a bit of boost etc) are pretty much the same anyway.
I guess at least the penrite stuff is somewhat Australian.
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975848
Redline or royal purple would be my choice but its too darn hard to source here in the switch. :laugh:
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2976280
I didn't say it was MY opinion, why is it necessary for me to back it up? I was simply stating that many people would prefer other oils over Magnatec in particular.
Oils aint oils?
Anyway i am about to try Mobil 1 5w50 in my car next service.... then im going to try the Motul Semi Synth 5w50 and see what the difference is.. i might also try a Penrite as i put it in my Gf's celica with 200,000 on the clock and it now works a damn treat..
I use to use the semi synth Motul in my silvia and it never had a problem.
Guess i will just see how it goes..
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2977740
I have been using Royal Purple for the last 40,000kms and love it previous owner used ELF (not sure on details) but engine did feel better with the royal purple in it. Wont be changing to anything else from my experience so far.
Interested to know what price is this Penrite SIN?
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2977910
HAW HAW HAW!!!
You would make a good redneck man.
I use 10W60 Catrol and my engine has never been better i think.....
WTF is Royal Purple??
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2977980
Hmm that rimindes me, i should start putting better oil into my 200,000 stooooockoooo lancer. that isnt my dads crap "BALCK AND GOLD!!!"
plus when i finally get that lovely peice of laminated License i will be giving him a full detail :glare:
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2978267
giving your dad a full detail?
talk about keepin it in the family.
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2978288
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
