Did an oil change today and used motul due to it being more readily available here than my regular drop.
Whilst at repco I saw an all synthetic from penrite called SIN. Has anybody had any experience with it. Going by the price it would want to be some good schizzz.
https://www.sau.com.au/forums/topic/160255-penrite-sin/
Its the one I was telling you about. 5w60 >_<
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975671
My mechanic would agree with that! He thinks using any penrite product is a sin!!!
HAW HAW HAW!!!
A mechanic I know would say anyhing else is a sin! >_<
He has been trying to blow up his 200 000km stock bottom ended 350awkw GTR for years and cant...he attributes some of his lack of success to this oil!
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975700
I used to use Penrite in my first 33....I liked it and it was recommended by quite a few workshops...I reckon this stuff would be pretty good..they seem to know what they're doing...I used Motul in my other cars though...and also found that to be reasonably good.
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975710
yep, penrite has had some good history on its side. A few racing cars and been making oil for donkey's years etc....
Tried motul and switched, I've been using the royal purple and really happy with that. Great oil temp and pressure stability, good friction resistant and seems to come upto pressure quicker (than the motul i was using prior). On the skyline I think the royal purple has the history and the creds- especially with hi end gtr's etc. A lot of top jap workshops have used the royal in the past.
That's my pref, for what its worth...
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975820
A mechanic I know would say anyhing else is a sin! :laugh:
Haha, I think most of the top end oils in fairly stock cars (ie a bit of boost etc) are pretty much the same anyway.
I guess at least the penrite stuff is somewhat Australian.
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2975848
Redline or royal purple would be my choice but its too darn hard to source here in the switch. :laugh:
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2976280
I didn't say it was MY opinion, why is it necessary for me to back it up? I was simply stating that many people would prefer other oils over Magnatec in particular.
Oils aint oils?
Anyway i am about to try Mobil 1 5w50 in my car next service.... then im going to try the Motul Semi Synth 5w50 and see what the difference is.. i might also try a Penrite as i put it in my Gf's celica with 200,000 on the clock and it now works a damn treat..
I use to use the semi synth Motul in my silvia and it never had a problem.
Guess i will just see how it goes..
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2977740
I have been using Royal Purple for the last 40,000kms and love it previous owner used ELF (not sure on details) but engine did feel better with the royal purple in it. Wont be changing to anything else from my experience so far.
Interested to know what price is this Penrite SIN?
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2977910
HAW HAW HAW!!!
You would make a good redneck man.
I use 10W60 Catrol and my engine has never been better i think.....
WTF is Royal Purple??
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2977980
Hmm that rimindes me, i should start putting better oil into my 200,000 stooooockoooo lancer. that isnt my dads crap "BALCK AND GOLD!!!"
plus when i finally get that lovely peice of laminated License i will be giving him a full detail :glare:
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2978267
giving your dad a full detail?
talk about keepin it in the family.
https://www.sau.com.au/forums/topic/160255-penrite-sin/#findComment-2978288
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
