Hi,
I think I've already arrived at an answer for this one, but I thought I'd double check that I'm not being too harsh on this car :cheers: . In the market for a skyline, had an RACQ inspection on a 1993 GTS-T, 102'000 km (offered for $13'000). I guess I'm interested to see if the condition report is out of the ordinary or not for a skyline of this age, I'm inclined to believe it's no good (advice from friends) - I'll ring the inspector to verify my decision, and check if a compression test had been done while I'm at it. Just painful thinking ahead to how many such checks I may need to go through before I get a clean bill of health, as they're reasonably expensive :happy: . Anyway report was as follows (in summary car was rated to be in reasonable condition, with some items requiring attention). Main concern is seepage from differential.
Defects requiring attention
- Oil seepage differential centre, rear of gearbox
- No evidence of rear steer operating
- Plug missing spare tyre well (and spare tyre not present)
Other items noted
- Fluid seepage rear of clutch master cylinder
- Oil seepage lower engine
- Oil seepage air conditioning compressor
- Surface rust left sill panel seam
- Left door lock surround loose
- Scuff marks lower section from bumper bar
- Bottom of left rear guard damaged, surface rust on same
- Surface rust noted under boot areas, heavy rust left rear inner sill panel
- Sill panels / floor frames dented
- Pads worn, monitor
- Sections of exhaust system corroding, front shields, muffler in particular
- Outer tie rod ends dust boots leaking grease
- Front struts dust boots broken/loose
Any feedback would be appreciated!
On a side note, can anyone recommend a Jap performance workshop that carries out pre-sale inspections?
Thanks,
Jade.
Edited by lee81
https://www.sau.com.au/forums/topic/160489-buying-a-1993-skyline-gts-t/
Sorry should have included that, it's an R33
Then thats easy, dont buy it :D
In all honesty it seems high price for a car that has some issues and it is the oldest of the r33's, i mean its the same age as my 32 ( I know which I'd have, haha :D ... you will never find a car that is perfect but its how many little issues you are prepared to accept. For that kind of money my mate got a mint R32 GTS-T but he did very well. I got my car a bit cheaper but its was stock as which i wanted and the paint was stone chipped etc cause the owner lived in the country, but i got a respray for $2k and got an exhaust, soon to get rims and suspension and with that I will have a car that I am very happy with. My main focus was a mechanically sound car.
To me it sounds like you need to see a few more and bring a friend, second opinions are always good. Best of luck
Edited by r32line
Thanks for the advice, that's 5/5 recommendations against (having asked friends).. damnit! :rofl:. So I'll have to look at some others, I might consider it if there's a significant drop in price, but otherwise I'll keep looking. Unforunately I'm keen on getting dark blue paintwork, and there's not nearly as many of those around as white/red/black models. I rang the inspector, he said while there is seepage he doesn't consider it a major issue to fix (causing long term drama), should just be a case of replacing the seals. Compression test had been done ('power balance' check as they list it), and results came out normal. His primary concern was rust, mostly surface rust, and one particular area around boot where it was getting a bit deep. I'm more concerned about engine condition, which he considers ok, seems it's more cosmetic issues with rust, suspects it has not been garaged (and that resale value will suffer if rust continues), as has more rust than a usual import.
Yeah like you said if it drops in price then you can consider it, but at $13,000 for a 93 model it would want to be better than it is.
The rust is a concern to me, on imports some of the cars in japan are driven in areas where it snows and they put salt on the road, this is bad news for the car as rust is a likely result. If it has already got rust arrears its not a good sign and a year later you could find it to be a lot worse.
So put all that to the seller and say at its current price it is not in your consideration, but you may consider it if its cheaper and u can spend money on it getting it all sweet.. Has it got any mods, or rims/kit/stereo? if not for $13k its quite pricey for what it is..... with the rust that is "getting a bit deep" and has your mechanic concerned then you really need to think if its worth considering at all. If so come up with a price that you would pay and be happy and then negotiate but do NOT go above that price.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
