have seen in other posts and read up about it and have seen kits for r33s where all the piping runs back to the original factory piping.
This includes the far side drivers side pipe where u usually have to cut a hole in the enginebay to feed the pipe through.
after seeing kits that dont require you to do that, and have the far pipe run "under" the cooler back to the passanger side factory pipe, i became interested in getting one of those pipes made up for me.
but after speaking to someone , they suggested that it wouldnt work cause something to do with "the pipe is to long for the pressure to go through".
Does anyone know if this will work, or there is some restrictions in doing this?
i mean there is kits out there that sell this "custom" type piping as part of the kit....so it must work...right?
so my question really is, will running the drivers side intercool pipe back under the cooler back to factory pipes work?
cheers
https://www.sau.com.au/forums/topic/160641-fmic-kit-piping-question/
cheers
yes,i have a blitz lm front mount that uses the same piping, and have not had any problems at all
I have personally had pipes made up for htis configuration on my last r33, on my new r33 i have the kit which requires hte hole cut.
IMO i belive the first option using hte two stock engine bay pipes is better. I feel better response and better cooling performance.
So yes u can just buy any front mount and get the pipes made up, Gilmore racing developments did it to mine way a few years ago, they are in brisbane tho.
ok cool
getting the pipe made up isnt a problem as my family friend works in that kind of industry.
but just that someone said that it wouldnt work cause the distance....i didnt see how that made sence as the other pipe that requires the hole cut out is still a pritty long pipe.
just needed clarrification that doing this would work
cheers guys
I have a FMIC that has a near center core inlet and outlet. Having the inlet near centered allows a 180degree bend.
Mine is setup so that the hot air runs from the turbo obviously then under the fmic to the drivers side, 180degree bend and in to the core. The cooled air then has a short run to the cross over pipe.
Appears to work fine. I'm going to be selling it soon as I need something a little bigger to support 300rwkw odd.
This one appearently has a 1.5psi pressure drop at 580hp worth of air so it could probably do it but..... I want a newy. :P
Ahh yes.. When I had mine out giving it a clean I measured up and I couldn't see a way that the 600mm core would fit with a 180degree bend back underneath. Probably could but it looked possible with the 450 and obviously is. :wave:
I run a 450mmx300x90mm core with slightly off center positioned in/outs as I mentioned earlier.
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
