have seen in other posts and read up about it and have seen kits for r33s where all the piping runs back to the original factory piping.
This includes the far side drivers side pipe where u usually have to cut a hole in the enginebay to feed the pipe through.
after seeing kits that dont require you to do that, and have the far pipe run "under" the cooler back to the passanger side factory pipe, i became interested in getting one of those pipes made up for me.
but after speaking to someone , they suggested that it wouldnt work cause something to do with "the pipe is to long for the pressure to go through".
Does anyone know if this will work, or there is some restrictions in doing this?
i mean there is kits out there that sell this "custom" type piping as part of the kit....so it must work...right?
so my question really is, will running the drivers side intercool pipe back under the cooler back to factory pipes work?
cheers
https://www.sau.com.au/forums/topic/160641-fmic-kit-piping-question/
cheers
yes,i have a blitz lm front mount that uses the same piping, and have not had any problems at all
I have personally had pipes made up for htis configuration on my last r33, on my new r33 i have the kit which requires hte hole cut.
IMO i belive the first option using hte two stock engine bay pipes is better. I feel better response and better cooling performance.
So yes u can just buy any front mount and get the pipes made up, Gilmore racing developments did it to mine way a few years ago, they are in brisbane tho.
ok cool
getting the pipe made up isnt a problem as my family friend works in that kind of industry.
but just that someone said that it wouldnt work cause the distance....i didnt see how that made sence as the other pipe that requires the hole cut out is still a pritty long pipe.
just needed clarrification that doing this would work
cheers guys
I have a FMIC that has a near center core inlet and outlet. Having the inlet near centered allows a 180degree bend.
Mine is setup so that the hot air runs from the turbo obviously then under the fmic to the drivers side, 180degree bend and in to the core. The cooled air then has a short run to the cross over pipe.
Appears to work fine. I'm going to be selling it soon as I need something a little bigger to support 300rwkw odd.
This one appearently has a 1.5psi pressure drop at 580hp worth of air so it could probably do it but..... I want a newy. :P
Ahh yes.. When I had mine out giving it a clean I measured up and I couldn't see a way that the 600mm core would fit with a 180degree bend back underneath. Probably could but it looked possible with the 450 and obviously is. :wave:
I run a 450mmx300x90mm core with slightly off center positioned in/outs as I mentioned earlier.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
