My car will be going in to get the turbo high flowed next week and I need to get my self a boost controller
I was wondering if any one had any recommendations as I want something that has at least 2 boost setting. And I don’t really want to spend over $400
I saw this GREDDY PROFEC TYPE-S BOOST CONTROLLER on Ebay for $400
Are they any good?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...p;rd=1&rd=1
Any info appreciated!
https://www.sau.com.au/forums/topic/160662-boost-controllers/
I’ve been sifting through my hpi mags and found the Gizzmo IBC. It looks pretty cool. 4 boost settings with a real-time digital boost display. Retails for $400. hpi have given it a pretty good review.
Any one else heard of these.
I don't think you'd need the power fc to control your ebc/evc. They do different things really. The power fc has an inbuilt boost controller that you can disable if you already have a boost controller or you can use if you don't have one. But neither is dependent on the other. Mind you, the power fc will help with your tune and this may help the boost controller to do a better job.
Why would you need four boost settings??
I have 2, one for all my driving 16 psi, and one for wet days 7 psi. This is basically an effort to stop wheel spin, a softer take off or turbo wind up.
You will drive on your maximum boost setting [but NOT maximum boost] 90% of the time. There is absolutely no advantage in driving on a lower setting, fuel economy etc isn't improved. Look at it this way, you have 18 psi as your normal setting, you are driving down the road at 120km/h, your still only using say 3 to 5 psi of boost [actually you'd be lucky to be boosting at all], the point is you are not using 18 psi. The only time you are using 18 psi is when you flatten it and hold it flat until boost peaks ie 20 seconds or more. And the only time you will do this is when you want or need to. ie overtaking a couple of b double semi's, showing off at the lights, track days. This is why you leave your boost on the higher setting, you never know when you need the power, and playing around with buttons may be too late!! Added to this, nearly all good boost controllers have a scramble setting for 10 seconds. You set this parameter yourself. What you do is nominate a peak setting that your motor can handle for 10 secs with no problems, say 22 psi. So you are overtaking the B doubles and you go WOT, your boost will actually try to go to 22 psi for the first 10 seconds then it will settle back to your normal setting of 18 psi. This will give you a little extra oomph as a first up hit. I'm not sure [i can check if needed, I did know more but have forgotten, you do all this stuff and set up your evc and then begin forgetting it] but I believe that this scramble setting may only work in the top gears, not in 1st or 2nd. This then ensures that your motor actually has a load on it for some protection against overboosting/reving.
I hope this helps.
You will drive on your maximum boost setting [but NOT maximum boost] 90% of the time. There is absolutely no advantage in driving on a lower setting, fuel economy etc isn't improved. Look at it this way, you have 18 psi as your normal setting, you are driving down the road at 120km/h, your still only using say 3 to 5 psi of boost [actually you'd be lucky to be boosting at all], the point is you are not using 18 psi. The only time you are using 18 psi is when you flatten it and hold it flat until boost peaks ie 20 seconds or more. And the only time you will do this is when you want or need to. ie overtaking a couple of b double semi's, showing off at the lights, track days. This is why you leave your boost on the higher setting, you never know when you need the power, and playing around with buttons may be too late!! Added to this, nearly all good boost controllers have a scramble setting for 10 seconds. You set this parameter yourself. What you do is nominate a peak setting that your motor can handle for with no problems, say 22 psi. So you are overtaking the B doubles and you go WOT, your boost will actually try to go to 22 psi for the first 10 seconds then it will settle back to your normal setting of 18 psi. This will give you a little extra oomph as a first up hit. I'm not sure [i can check if needed, I did know more but have forgotten, you do all this stuff and set up your evc and then begin forgetting it] but I believe that this scramble setting may only work in the top gears, not in 1st or 2nd. This then ensures that your motor actually has a load on it for some protection against overboosting/reving.
I hope this helps.
Thanks for the info that’s a huge help. Now I finally understand what a scramble setting is. That’s awesome. I was original thinking like 7 psi for the wet and 14ps daily driving and then a third when I want to smoke you at the lights :ermm: (just kidding)
But I guess I do only need 2 setting.
thanks heaps I really appreciate it
smoke us.... If I dont sell the beast I ll see you at WSID with some semi slicks lol, i pulled a 13.4 with 18's and some serious neg camber with only the stock turbo. 171 kph over the traps now the new turbo mmm should be great with slicks...
Get a Greddy Profec B spec II from the sponsors for $390 delivered like I did. Works like a charm, holds boost very well and quite easy to setup compared to AVC-R and the like. I road tuned it myself in about 20 mins on the freeway whereas most shops wanted to charge about $400 to tune the AVC-R on the dyno.. mind you a canberra workshop also quoted me $450 to fit and tune by Profec B too..
Here is the sponsors link
http://www.skylinesaustralia.com/forums/in...howtopic=154474
Edited by Paragon
That was always going to be fair challenge :rofl: his 218rwkw v my 172rwkw at that time lol
and now that i am down my set of 17"s with good rubber i would struggle even more.
why dont you just marry WSID... :rofl:
wasnt it around this time last year you were challenging someone else? was it leigh?
Even if you buy a cheaper boost controller you can have 4 settings on most as setting one: boost controller off (normal boost 7psi)setting 2: boost controller on about 10psi setting 3: 14psi and setting 4: scramble mode for overtake 16psi, but you can use your own settings for what boost you want to run. Always get your boost setup either on the dyno or on the street with an air fuel ratio meter as the more boost you put in means you are putting more air more air needs more fuel and also with higher boost there is a chance of detonation which can be caused by a number of things including ignition timing too high,bad fuel,high compression ratio due to boost or lean fuel ratio. It may cost a little more but if your engine goes you will be up for ten times that amount. Also buy the best controller you can afford as they they will have a tighter control on the boost curve, and the upside is it gives you room to go higher in the boost if you want to later on.
I have the Apexi FC Boost Control Kit which is an FC Addon not a stand alone boost controller like the Apexi AVC-R as seen here http://www.slidingperformance.com/catalog/...products_id=105
Sorry, my bad reading, yes, an apexi solenoid for a power fc is different.
Just a question for you guys.
When you guys get an aftermarket Electronic Boost Controller, what do you guys do with all the orginal Stuff?
EG, I have an Apexi AVC-D that came with the car when I got it but it's quite messy under the hood. do any of you guys do any clean up or just let the orginal solenoid stay there?
Michael
Michael
If you have an aftermarket boost controller then you can get rid of the standard solenoid and just cable tie the wiring away. I just did a engine bay clean up for trooper on his s2 r33 gtst. He has posted up some pics in the nsw forum if you want to check it out. It may give you some ideas on how to do it.
Hey thanks for that, I'll check it out.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
