Just wondering if there are anyone here that is living close to the sunnybank area and are into fish... Got a few question on how to setup me fish tank properly.. Abit of a newb with this so please be kind to me.. :( Are there any local queensland forums that are dedicated to fish stuff by chance?
https://www.sau.com.au/forums/topic/160803-anyone-into-aquarium-here/
My brother is big time into fish...he has 3 7foot tanks set up in his house! And his garage is full of breeding tanks...in fact his house is 'modded' to accommodate fish! ha ha..they had to get the garage aircondidtioned for the breeding and a new floor and support put in his living room to take the weight of the tanks ha ha!
I will ask him on Monday if there is any forums that can help you out..also I am sure he could sell you some fish cheap if you are into native species...that is all he has I think
check this site out:
http://www.qldcichlid.com/
and
http://qldcichlid.com/forum/index.php?action=forum
pretty good, covers a lot of different species, from natives, to tankbusters, to cichlids etc.
i had a 4 foot tank with a barramundi for a bit over a year... i bought him as a fingerling (about 2 to 3cm) and when he passed away he was about 40+cm.... in fact, i've got to get around to setting the tank up again... i might go with some silver perch or maybe a mangrove jack this time...
we had a huge 25cm oscar
we still got 25cm + oscars..
umm back to the OP..
if you want any advice on fish tanks etc.. i 1000% reccommend a fish shop on the southside..
I dont even know the name of it but its opposite the rocklea markets..
They have the most compettitive prices and can give you great advice on new setups etc..
apart from that yeah... forums are good too..
Try not to buy second hand.. as if you want ciclids or any freshwater and the tank has been saltwater.. you could kill the bacteria that keeps fresh fishy alive
Ill get some pics posted up of our Albino Oscar called Vito.. that mongrels HUGE (10.5")
Can anyone tell me what wrong with my fish???
The green is a definite give away.. either wayy to much algi in the tank ( needs filtration + charcoal)
or way too much Toxic waste spill to water ratio..
Toxic Crusader reccomends a 2:1 ratio for such tests..no super fish for u!
There is an AWESOME vet on the southside who runs a clinic call Brisbane Bird and Exotics Veterinary Service. She only sees birds and exotics, no cats or dogs. So if your fishies gets sickies, or you just want good advice, give her a call...... 3420 6773!
I have a 4' African tank I love the tangs have a great colony of frontosa Im looking for some largish Altolamprologus compressiceps at the moment if anyone knows where I might find some? been into fish and reptiles for a couple of years now.
here is a pic from about 2 years ago. There is now a lot less malawi's in there and the fronnies own the tank have put in a bit more coral too.
thats a really nice set up you have there,
but the frontosa and the venustus (excuse spelling) really need a larger tank. as both grow up to and sometime over a 12 inches..
my frontosa died 4 weeks ago when i moved house.. when we move agian in 12 months im planning on getting a 6, or 8 foot tank to get a colony of fronts :D
more to the point.. i hope that purple pipe on the right hand side of the picture is another 300L + capacity external filter.. sad thing about african fish is that they get dirty as the get older.. we got a fluval running and it still needs cleaning once a fortnight ( 1/3 water change etc)
but apart from that you look like you got a nice setup there dano... frame is awsome and the setup looks reefy :dry:
the Via Aqua 750 under the tank should do the trick, the internal filter is just to create some flow.
On the coral it is a bit of an unknown thing as I have been told many different thing from many different people which always seems to be the case, the chemist that lives next door reckons it will probably raise the ph a little making it more alkaline which is ok as the Africans handle it no worries.
Thee natural habitat in the rift lakes is quite salty and alkaline but they are a hardy type of fish to keep, I have never lost any to sickness just bad tempers! For those not familiar with African they do require a small amount of Rift Lake salt to be added with the water change.
stand is all made out of 25mm HD MDF and requires a small army to move, my dad made it for me to match my other furniture
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
