Hi guys,
Trying to clear out space from my shed.
Below are a list of parts I have to get rid of.
I'm located in Melbourne, would prefer pickup only however if interstate buyers can organise freight I dont mind selling outside of Melbourne.
First Parts:
Front door trims off a Series 1 R33 GTR up for sale.
Price: $250 for the pair.
Set of Bilsten Suspension in Excellent condition, these were on my GTR when it arrived from Japan, however I have since replaced them with Apexi Height/Damper adjustable coilovers. They are an extremely comfortable ride.
Price: $650
Set of HKS Hyper D Coilovers - Height and Damper Adjustable, I purchased these from Japan and bought them down with my GTR however there is a rattling noise on the rear which irritated me. The ride is comfortable, but the noise is quite irritating. Noise is coming from the rear suspension I think it was the left side.
They are up at a cheap price, not sure if its a simple fix or not, did not bother getting it checked out - ended buying Apexi Coilovers.
Price: $350 SOLD
These wheels came off an R33 Skyline I bought down a couple of years ago, they only came on the rear of the car as a pair, they've been sitting in the shed since then.
I'm not sure of the width but I would think they are either 9 or 9.5". They are 17" Panasport G7's. They are Forged wheels. I have attached a couple of pics of them when they were on the car to give you an idea how they look.
Price: $350 for the pair.
R33 Skyline Series 1 Spoilers. 2 White ones, 2 Silver Ones. Few scratches here and there, all with working brake lights. White one with the pic has sticky tape marks, can be polished off.
Price: $40 each
1 adjustable strut brace sold to me. already got it. looks good on and fits perfect for those that may doubt them fittin r33.
HKS Coilovers Sold, Another Cusco Adjustable Strut bar sold, 1 more left (however pending pickup from my work tomorrow). Also realised the other Cusco Strut bar is actuallly Adjustable and is for the REAR of an R33 Skyline.
All 3 Front Cusco Strut bars are sold, one Rear Adjustable Cusco Strut Bar remaining (for R33).
Following parts still available (Refer to previous posts for pics)
Panasport G7 Wheels x 2: Price Drop $300
R33 GTR Front Door Inserts: Price Drop $200
Bilstein Suspension for R33GTR/R34GTR/R34GTT: Price Drop $600
R33 Standard S1 Spoilers White x 2, Silver x 2: Price Drop $20 Each
Blitz Blow off Valve with Piping for R33 GTST: Price Drop $125
Further price drop on the following parts:
Panasport G7 Wheels x 2: Price Drop $250
R33 GTR Front Door Inserts (Pair): Price Drop $180
Bilstein Suspension for R33GTR/R34GTR/R34GTT: Price Drop $550
R33 Standard S1 Spoilers White x 2, Silver x 2: Price Drop $15 Each
Blitz Blow off Valve with Piping for R33 GTST: Price Drop $120
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
