Item: 1970 Ke11 Toyota Corolla sedan
Item Condition: Very Good for age
Reason for Selling: Moved to the country
Price and Payment Conditions: $3600
Extra Info:
1970 Ke11 Corolla, Its a sweet crusier but has a bit of go and a
handles quite well for a ke1x.
Body
Ke11 shell
Early ke10 tail lights
90% rust free
Metallic Cardinal Red
debagged boot
Venetian
Engine & Drivetrain
4k
3k head
32/32 weber
Genie extractors (4 into 1)
Ke55 5 speed box
Slight oil leak, Doesnt blow smoke that Im aware of
Brakes, Suspension and Wheels
ke70 front discs and calipers
Whiteline front swaybar
Lowered and stiffened all round
White 14" 4x110 custom steel rims
ms65 crown hubcaps
whitewalls
Tyres getting low on tread but still legal
Interior
Original cream interior all matching (including roof lining)
Newish black carpet
Kmph dash
10,00rpm tacho
Retrimmed dash pad (black)
New retractable seat belts
Boxed and carpeted boot (black)
Pioneer 50x4 cd player
Pioneer 3way 6x9 rear speakers
Pictures:
Now had chrome drivers revision mirror
Steering wheel horn button slightly different...
Contact Details:
**Just out of rego, will renew at no cost if sold for $3600**
Post on here or PM
OR
0419186811
Lee,
Rust isnt too bad. there are small patches behind rear wheels.
Main issue is bog thats cracked on parts of the front guards and
bonnet. sounds alot worse in writing than it is.
Price is negotiable but i've had offers for $3200 so they would have to
be better than that and it wouldnt include rego.
cheers
Scott.
  • 2 years later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
