Hi i have 2 x P4 2.8 ghz ibm computers
each computer has the following specs
p4 2.8 hgz
512 mb ddr 1 ram
scsi controller
scsi 70gig hdd (note this is not a IDE or SATA or SATA II HDD) SCSI hdd get used on fast servers.
cd-rom
floppy
onboard 10/100 eathernet
onbaord sound
onboard video capable of AGP video
USB 2
LPT printer port
looking for $300 each ono
1 x p4 2.5
512mb ddr 1 ram
40gig IDE hdd
CD-ROM
floppy
onbaord sound
USB 2
LPT printer port
looking for $300 ono
10/100/1000 JGS616 Netgear switch as new make a reasonable offer.
AMD X2 Dual 3800+ 1 gig ram- dvdrw -7300 256mb pci exp video-gigabyte tower, this has about 400 gigs of hdd space, make an offer.
if you are interested in a server PM i have a dual 2.4 xeon which i have no need for as well has 600gigs hdd + 3x 18gig scsi + 2x36gig scsi hdds
these were all my testing machine and i have no need for them now need to clear out all my computer crap around the house
few xeon chips as well 1.5 and 2.4 make an offer
location sydney
contact: [email protected]
https://www.sau.com.au/forums/topic/161551-computer-crap/
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
