Hi guys
I have a pretty stock SII R33 Sedan, BATMBL split dump and metal cat, xforce S/S 3in, pipercross high flow panel filter and a Turbosmart E-Boost 2 set for 8 PSI, 140K KM regularly serviced. Yesterday after after giving it a bit (6K RPM gear changes, was only up to 70 Km/h on a highway with no other cars) i heard a strange sound, then when slowing down to turn onto my street i heard a high pitched whine coming from the engine bay, i pulled over straight away and popped the bonnet, and could hear what sounds like exhaust gas leaking from around the turbo heat shields. It sort of sounds like when i got to drive my car with just the front pipe and cat with no catback on. I can hear what i assume is the turbo spinning up but really metallic whiney.
Is my turbo stuffed or is it more likely a blown gasket, im hoping its the turbo/dump pipe gasket, as im sure i can hear the turbo clearly. Or probably more likely snapped studs in the manifold, and thats leaking, as the roads where i live are not the best and fairly rough.
I have a highflow R34 turbo ready to go on, but no supporting mods if it is the turbo :P, would that be safe to run at the standard boost level. I realise it wont be the stock 6-8Psi if the wastgate is set that way, and that airflow is relative to the turbo itself.
I was thinking if it is the manifold gasket / head studs then i might send it away to be extrude honed and high temp paint coated. Who does this again?
anyone experienced this, have any comments?
cheers
Evil
https://www.sau.com.au/forums/topic/161769-weird-noises-from-my-engine-bay/
It'll be manifold gasket, 140k km's... its prime time.
Get it checked, but thats likely it.
Also ensure ALL manifold studs are replaced when they change the gasket, this is very important.
Also change out the other gaskets, turbo/dump etc. As you dont wanna have to do it all again in 6-12 months
Cheers guys thanks for the replies. I will try to check under the heat shields tomorrow. If it is the manifold gasket, will it be safe to drive around like that for a little while? As i live in broome and i doubt they will have all the gaskets available straight away, and this is my daily driver. Are SI and SII R33 exhaust manifolds the same?
Good advice on the gaskets and studs Nismoid, i will do that :unsure:
Anyone got a rough idea how much the 3 gaskets and the manifold studs (how many are there?) will be? and roughly how long it should take to do this work? assuming no snapped studs or other complications.
cheers
Evil
Went to the local nissan dealership and ordered the 3 gaskets plus the exhaust manifold/head studs/bolts. Its gonna cost around $230 just for the parts. One of the guys from the service dept had a look/listen and reckons its likely the manifold/head gasket, Im still hoping its the turbo/dump pipe gasket :P. Gonna get a service done at the same time, cheaper to check spark plugs with the x-over pipe off already ;).
Evil
Update
Took the car in and they ended up charging me $497 (with an oil change, basic service, i supplied the oil, thats including the gaskets and studs) to tell me they didnt know what the problem was and they reckon its the turbo on its way out. They couldnt find any signs of exhuast leak anywhere :). According to this thread http://www.skylinesaustralia.com/forums/in...howtopic=160702 it sounds like we have a similar issue. Anyway looks like my GCG highflow will be going on next week at a bigger cost to me :P, no supporting mods though, so i hope it will be safe.
cheers
Evil
Turns out it was my stock SII Turbo. A piece of turbine wheel came off unbalancing the shaft and rooting the bearings sad.gif. Good thing i had a GCG R34 Highflow waiting to go on. All fixed now, and more powah and more noise sad.gif. Must remember highflow with no supporting mods is a not good (for the wallet) wink.gif.
Cost me another $400 to replace turbo, a few seals, and radiator flush. They charge $95 an hour for labour.
cheers
Evil
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
