**r32** Skyline 300 Km/h Speedometer Cluster Kits - $100 Delivered
Which colour would people prefer?
101 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
white with blue led. please answear above post thanks, also i have another question, is it possible the change the colour of the needle seperatly to the cluster lights, i want blue cluster with red needle like my apexi el2 gauge.
  • Replies 60
See....i would think not....considering the 32 speedo drive is cable and not electronic.
Explanation of how it will read 300????
If it really does read 300 ill gladly purchase.
White for gtr thanks.
yes the R32 cluster is indeed cable driven. we are currently working on the recalibration procedure and should have a solution soon. once we have sorted that out I will be able to get a design drawn up and posted on the forum.
regardless of what colour LEDs you install in your cluster, the needle always illuminates red.
CALIBRATION: the R32 being a mechanical speedometer drive, an additional unit will be required to be purchased to change the ratio of the needle movement. The unit will cost something like $150.
wow just stumbled upon this!! :kiss:
White for me & GTST.
Regarding the gtst's being mechanical... The signal is converted to an elec signal in the cluster and then sent to the ECU.
Is there anyway to modify that signal there or impossible?
A mob here in SA do the speedo ratio box's, apparently for ~$110 but will double check monday.
Beale Instruments
+61 8 8445 6644
I'll be needing the ratio box anyhow so its no biggy for myself. :P
damn, i just stumbled upon this too, damnit :)
i saw the 33 one a while back they look awesome
I've got a GTS4 :S
so same dials as GTS-t except the left hand side has a torque splitter in place of the boost guage(like GTR)
are you able to do one for me in black?
Beale Instruments
+61 8 8445 6644
I'll be needing the ratio box anyhow so its no biggy for myself. :)
let us know about the ratio box, what maximum speed is the ratio box designed for? that will determine the max speed on the speedometer for this kit.
You could also do round 260kph kits or 240kph maybe?
just add the numbers on after the 180? as I know my speedo goes way past the 180kph on the track
The bloke said the max speed isn't an issue. BUT he would need a speedo example as to make the box up as its not adjustable.
The other option is to have the speedo recalibrated which is $90.
He seemed to think the speedo box wouldn't work; unsure why as demagnetising or magnetising the speedo is the same as changing the cable speed. He wasn't all that clear but from where I am I can't see why it most definitely wont. Maybe a Morning thing. lol
I have a spare R32 GTST cluster here that I can send down. What the instrument guy would need to do would be to recalibrate the ratio so that at the current 180 km/h mark, the speed reading is 300 km/h (or 320 whichever is easier) and then I would get the speedometer face designed accordingly.
send me a PM if you are able to arrange this for us and I will send you the cluster.
I can get the speedo recalibrated at 300km/h or 320km/h depending on how you plan to space the numbers etc. He charges $90 to do so.
Thinking more about the ratio box. Its definitely not going to work. It will work with respect to displaying the correct speed on the dash with the new faces BUT it will slow the odometer and incorrectly report the amount of km's travelled.
So for our Mechanical R32 speedo's the ONLY way is to drop the cluster in to an instrument shop to be calibrated.
PM me if your still interested in doing this... Postage costs etc etc it may be worth while finding a local bloke?
well our local instrument shop who is very good had the cluster for a couple of weeks but couldnt find a practical / inexpensive solution to the problem.
I guess the way to go if we want to get this happening would be to leave it up to the individual to organise their own calibration with their local instrument shop? what do you think?
I'm fine with that.
As we come across instrument shops within our own states it would help full for all of us to post their details.
They appeared fairly certian that magnetising or demagnetising the speedo wouldn't affect the odometer. What are your thoughts? :S
guess we will just have to suck it and see.
now that the calibration is out of the way, I will get some design pics posted here in the next few days.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
