**r32** Skyline 300 Km/h Speedometer Cluster Kits - $100 Delivered
Which colour would people prefer?
101 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
white with blue led. please answear above post thanks, also i have another question, is it possible the change the colour of the needle seperatly to the cluster lights, i want blue cluster with red needle like my apexi el2 gauge.
  • Replies 60
See....i would think not....considering the 32 speedo drive is cable and not electronic.
Explanation of how it will read 300????
If it really does read 300 ill gladly purchase.
White for gtr thanks.
yes the R32 cluster is indeed cable driven. we are currently working on the recalibration procedure and should have a solution soon. once we have sorted that out I will be able to get a design drawn up and posted on the forum.
regardless of what colour LEDs you install in your cluster, the needle always illuminates red.
CALIBRATION: the R32 being a mechanical speedometer drive, an additional unit will be required to be purchased to change the ratio of the needle movement. The unit will cost something like $150.
wow just stumbled upon this!! :kiss:
White for me & GTST.
Regarding the gtst's being mechanical... The signal is converted to an elec signal in the cluster and then sent to the ECU.
Is there anyway to modify that signal there or impossible?
A mob here in SA do the speedo ratio box's, apparently for ~$110 but will double check monday.
Beale Instruments
+61 8 8445 6644
I'll be needing the ratio box anyhow so its no biggy for myself. :P
damn, i just stumbled upon this too, damnit :)
i saw the 33 one a while back they look awesome
I've got a GTS4 :S
so same dials as GTS-t except the left hand side has a torque splitter in place of the boost guage(like GTR)
are you able to do one for me in black?
Beale Instruments
+61 8 8445 6644
I'll be needing the ratio box anyhow so its no biggy for myself. :)
let us know about the ratio box, what maximum speed is the ratio box designed for? that will determine the max speed on the speedometer for this kit.
You could also do round 260kph kits or 240kph maybe?
just add the numbers on after the 180? as I know my speedo goes way past the 180kph on the track
The bloke said the max speed isn't an issue. BUT he would need a speedo example as to make the box up as its not adjustable.
The other option is to have the speedo recalibrated which is $90.
He seemed to think the speedo box wouldn't work; unsure why as demagnetising or magnetising the speedo is the same as changing the cable speed. He wasn't all that clear but from where I am I can't see why it most definitely wont. Maybe a Morning thing. lol
I have a spare R32 GTST cluster here that I can send down. What the instrument guy would need to do would be to recalibrate the ratio so that at the current 180 km/h mark, the speed reading is 300 km/h (or 320 whichever is easier) and then I would get the speedometer face designed accordingly.
send me a PM if you are able to arrange this for us and I will send you the cluster.
I can get the speedo recalibrated at 300km/h or 320km/h depending on how you plan to space the numbers etc. He charges $90 to do so.
Thinking more about the ratio box. Its definitely not going to work. It will work with respect to displaying the correct speed on the dash with the new faces BUT it will slow the odometer and incorrectly report the amount of km's travelled.
So for our Mechanical R32 speedo's the ONLY way is to drop the cluster in to an instrument shop to be calibrated.
PM me if your still interested in doing this... Postage costs etc etc it may be worth while finding a local bloke?
well our local instrument shop who is very good had the cluster for a couple of weeks but couldnt find a practical / inexpensive solution to the problem.
I guess the way to go if we want to get this happening would be to leave it up to the individual to organise their own calibration with their local instrument shop? what do you think?
I'm fine with that.
As we come across instrument shops within our own states it would help full for all of us to post their details.
They appeared fairly certian that magnetising or demagnetising the speedo wouldn't affect the odometer. What are your thoughts? :S
guess we will just have to suck it and see.
now that the calibration is out of the way, I will get some design pics posted here in the next few days.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
