Selling my GTR, Moving into real estate market. Not only that, I simply dont get the time to drive this amazing machine, so it should go to someone who can appreciate it.
List of mods:
HKS GT-SS Sports Turbines - Ball Bearing 320hp each
HKS Split Dump Pipes
HKS stage 2 cams and springs
Twin 3" Front Pipes into single 3.5" Exhaust. N1 Style Muffler
N1 Oil pump
N1 Water Pump
OS Giken Triple Plate Clutch R3C
Lightened Flywheel
Genuine Nissan N1 Block ($3,500)
GTR Crank (replaced)
Adjustable Cam Gears
Apexi Power FC 'Plug N Play'
Apexi Electronic Boost Controller Kit
Apexi FC Commander Hand Controller
Apexi Super Intake kit for 80mm AFM's
Apexi GT Spec Intercooler (no longer in production) 136mm Thick
R33 Gtst 80mm AFM's <Used
Greddy/Trust Oil Catch Can
Greddy/Trust Intercooler Piping Kit
CP Forged Pistons
Tomei Metal Head Gasket
NISMO Fuel Pump
600cc injectors
Apline MP3 Headunit w/remote
Alarm System with Remote Central Locking
Bride Reclining Racing Seats (possibly non-genuine?) w/genuine rails, nearly new
Nismo Duracon Gearknob
TEIN Super Street Coilovers (Adjusted for Australian Streets, Height and Dampening Adjustable)
Front Strut Brace
Michelin Pilot Preceda Tyres on stock GTR rims
Slotted Brake Rotors and Bendix Pads
Making 350hp at all 4, 1.2 bar. The car is still running on a base tune from engine build. Would easily net well over 300kw at all 4 with time on the dyno.
I have all receipts for work done, totalling well over $20,000. Most work including rebuild performed by Gavin Wood Autotech in queensland, within the last 24 months.
Please, no more 20k offers, any serious buyer can see the value in a car of this calibre.
Price is $24,000. Rego is due 15/06/07, will sell for $25,000 with 12 months NSW rego.
Contact via email is best - [email protected]
Thanks.
Edited by mitchy
https://www.sau.com.au/forums/topic/161963-silver-r32-gtr-modified/
Very nice car indeed...
How many kms on the chassis?
And how many kms on the rebuilt engine?
Whats stopping you finishing off the tuning and then telling us its full potiential?!?!
evo201 - Nice lancer, but not interested in swapping, as i dont drive this car as it is. Best of luck with the sale though mate.
ordinary - From memory, chassis has 128xxx km on it, these are genuine. Motor and all mods have done 20k or less. The reason I havent had it tuned and played with it a bit more is simple - I am at work sunup to sundown and beyond, almost 7 days a week.
I havent driven it in 5 weeks, let alone thought about tuning it. Besides, the thing is more powerful than i need, so I never found it an issue.
That said, figures are everything these days, so people should have little trouble seeing the potential in this setup.
Damn this is pretty much exactly what i want, at a good price.. Can't believe no ones bought it yet..
Can get a return flight to sydney for $150 so thats not too bad, what part of sydney do you live in?
Also can you send me some more pics (i'm trying to decide whether i like the colour) to [email protected]
Cheers
Edited by r32 gts-turbo
How's the rust situation, inside the rear guards, and forward rear cradle mounts, boot etc?
Also, will you consider selling the car a little cheaper if you de-register it?
How old is the clutch?
Did the crank go in stock, or is it fitted with an oil pump drive extension, or an R33 crank?
Last of all, what year is it?
I cannot locate any rust in the chassis at all.
Clutch put in at engine rebuild, less than 2 years ago, less than 20k on it.
Crank, I believe, is R33 crank.
Car is 1991 model.
Cheers mate,
Mitch
Edited by mitchy
  • 4 weeks later...
Another price drop, $24,000.
Cheers,
Mitch
Awesome job mate... :dry:
Any chance of an interior pic/s??
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
