hey guys,
i have a question, i just had a cooling pro FMIC fitted, can any one tell me if it is multi-directional or not, i would have thought not, but im not a mechanic. it just seems odd to me that the sprayed on logo is facing inwards rather than outwards.
https://www.sau.com.au/forums/topic/162138-fmic/
hey guys,
The cooling pro coolers are perfectly symmetrical in every direction.
You can run the cooler any direction it doesn't matter. Whoever fitted it just fitted it with the writing facing towards your car, you could remove it and flip it over if you want, it doesn't matter.
https://www.sau.com.au/forums/topic/162138-fmic/#findComment-3011847
hey guys,
The logo is normally on one side only, so you can choose to have the logo showing or not.
You should be able to take your intercooler off and just reverse it if you want you show your logo off.
https://www.sau.com.au/forums/topic/162138-fmic/#findComment-3012710
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
