Previously owned by Frink.
Im selling my R31 Series 3 1987 Silhouette.
Rego till 31/08/2007
Has: Extractors
Full 2 1/2inch exhaust?
Cold air intake and pod
New front and rear brake rotors and pads
Has a towbar too.
Stereo:
Head unit stolen recently, rest of car fine from break in.
Sony 10 stacker (needs headunit to control it)
Sony Explod speakers
Also comes with power inverter, cables for Sony PS2 wired in, cables wired in for a amplifier in the boot and an input/output box behind dash.
PM or call 0421780262
$1400 negotiable. Also selling starcorp wheels for extra $500 neg.
(comes with centre caps)
Will also come with 3 months rego!!!
Reason for selling: Datsun needs injectors asap.
Edited by datto260Z
https://www.sau.com.au/forums/topic/162141-fs-r31-series-3-1987-silhouette/
  • Replies 44
It has aircon, but not working atm. However, if it doesnt just require a re gas, i have a spare aircon pump to go with it. Its winter, so i couldnt justify getting it fixed till spring, then I decided to sell.
Conversions not too expensive anyway, i just had the 200 regassed and if it was old gas it was like an extra $100. So im not too bothered.
basically i need a tow car for my datsun when its built. So this would be good as a daily/tower if i get a tow pack on it.
I have to sell my 200 first though :D then i can join the skyline club el proper :(
Luke just told me it never worked for him :D
I forgot to put in that it has a tow bar, but im unsure of the tow rating. I have to get a loom for the lights, but i am getting that this weekend off a mate for free :(
What datto u getting?
I have a Stanza in my garage, its being prepped for hill climb/circuit, i have a forged L18 with custom flywheel and rebuilt SSS 5 speed, sparco harness custom mounted seat, the whole shebang. Just putting it all together still. Have been for the last 3 years :huh:
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
