  • Replies 132
depends on wat rear housing wat you use but yer should be 300+ rwkw
ok whatever even with the smallest housing .64 u can get 300rwkw with 13-15psi! opps and cams
cheers
and i dont think i deserved that warning.... but on the other hand i dont really care..
cheers beer baron
https://www.sau.com.au/forums/topic/162228-300rwkw/page/7/#findComment-3110558
omfg.... USE THE SEARCH BUTTON, or read the FI forum. We've been talking about 300rwkw all damn week!
http://www.skylinesaustralia.com/forums/in...80&start=80
maybe YOU should USE THE SEARCH BUTTON, this "300rwkw" thread was created long time before yours.
https://www.sau.com.au/forums/topic/162228-300rwkw/page/7/#findComment-3112170
Um^^^^ who was that aimed at.
doesn't matter if mine was created after or before this thread.
There must be about 100 threads getting around on people who have achieved 300rwkw+, and there is even plenty of cars posted in the dyno results thread.
No wonder this thread has gone to shit, judging by some of the replies.
Some people need to wake up to themselves.
https://www.sau.com.au/forums/topic/162228-300rwkw/page/7/#findComment-3112230
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
