they r good. period.
seriously...they tune cars well. one thing i learnt from them is that my spark plugs should not be .85 but 1mm or sumthing like that.
had them do my servicing three times n my car's running well. plus they installed all the mods n tuned my car. ask slip or abu53 how it goes.
https://www.sau.com.au/forums/topic/16228-chapman-chapman/#findComment-332376
why cant we go into details? is this the case? could someone explain to me why? correct me if im wrong, but this is a discussion forum for discussions right? is it because a business name is involved? we talk about getting bad batches of fuel from shell, bp or whatever, and no one seems to mind. they are actual experiences and not something we whipped out of our arses. rb26 speaks highly, i speak highly, and im sure many speak highly of chapmans, but if the people who have had bad experiences, can't share their experiences isnt the story a little one sided? we may as well all be making statements instead of asking questions and having a DISCUSSION! so please, for those that have had a bad/good experience, PLEASE DISCUSS!
https://www.sau.com.au/forums/topic/16228-chapman-chapman/#findComment-333682
rb26's car goes like a rocket, very smooth (except for the clutch)
Atomic, no no no. If we have ph and hungry6, part of SAU, posting on SAU forums saying negative things about a workshop, theres a whole lot of SAU in there. We do not want bad relations with workshops ESPECIALLY in this instance, where there are obviously a number of happy customers. We keep it in PM and email in this situation. You would be very unhappy if you were the workshop concerned, they probably have no idea about this thread, and therefore no chance to reply. If they did it would most likely get very messy if people less controlled than ph and hungry6 were involved. This has happened more than once in the past.
ph and hungry6 - thank you.
https://www.sau.com.au/forums/topic/16228-chapman-chapman/#findComment-336115
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
