Hi!
Here is my setup:
rb30det
040 fuel pump
stock everything(exhaust)
3.9 final gear
205/55/r16 tires
I was trying out my car today. My friend had my mobile with countdown timer , so he was sitting in the passenger seat, counting.
With moderate spin from start - high 9sec to 100.
Feels quick, but timer spoils the fun LOL.
I even tried to use 2nd gear(no upshift to 3rd) to 100. Same result.
Surface was a bit rough. Asphalt covered with dust.
What I was able to see though, that in 1,2,3 gear after about 5-6k the boost gauge needle drops from stock 0.7 to 0.5. Maybe a bit earlier. But I can't say for sure. Car Idles fine. No jumpy revs.
No leaks after AFM/before turbo.
So what's causing this boost drop ?
And what about acceleration ? I think it should be in 8sec range.
Thanks!
Edited by robots
Thats how the stock RB20 turbo/actuator is dude.
You need a stronger actuator, or a larger turbo (well.. both would be ideal).
The little RB20 turbo does have a fair task on its hands :happy:
R31Nismoid, c'mon.
It can't be 9-10 sec to 100.
Something ain't right there. It should be around 8sec mark.
I have stock exhaust btw. So where should I dig ? Gap the plugs to 0.8 ? Clean coils ? Try manual boost controller ?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
