Hi all
I have a strange whistle/Squeak at idle in my car. It is constant, and as soon as i blimp the throttle it disapears. Only occrs after the car has warmed up. I have all new gaskets and studs exhaust side.
It is hard to see where the noise is coming from, and as you turn the car off, it dies down with the engine.
No recently i cleaned my TB, and Cold start valve, and have since look at these again, but i cant find any issues with these. The engine hasn't lost Vaccuume, and still dirves fine.
Is it possible that it is a whistle from the TB or something similar.
https://www.sau.com.au/forums/topic/162821-whistlingsqueaking-at-idle/
i have the exact same problem = and the same symptoms . the it is really hard to diagnose where it is comming from . sounded like any air leak at 1st, but then it changes tone a bit . my car has been sitting for a few months with out more than a 100 meter drive which iv done like once ever few weeks.....
if i knew where it could be from id be looking for ways to fix , iv just given up.
i have the same squeek at idle goes away while driving..... not sure if its the belts or what.... sounds real dodgy when idleing and gets louder when its hot and been driven for a while.....could it be the cooling fan bearings?
  • 2 months later...
Check all three belt tensions first - make sure they are not loose.
I suspect the sound is coming from the bearings on the air con compressor pully - the one on the compressor - not the tensioner pulley.
I had a noise I couldn't identify - I just got a new water pump fitted so it wasnt the issue.
So I took off the power steering pump belt and the noise was still there.
Then I took of the aircon belt and presto - the noise was gone!!
I rotated the pulley on the air con compressor by hand and it was extremely noisey - you could feel the "roughness" when rotating the pully.
Try it yourself and see.
The CAS noise sounds like a rerw rew rew rew rew.
The air con pulley noise is more like a metal squealing or squeaking - and is constant. Not pulsing like the rerw rerw rerw of the CAS
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
