  • Replies 155
also guys have to wear dress shoes as well. so no skate shoes or u might not get in.
Correct - no sports sneakers. You might get away with street-style shoes (like Diesels, etc.) though - I have in the past.
Jess...
Ummmm I am out... no car (both will be off the rd this weekend) and I am pretty sure we are the only ones from the coast coming this month.... Public transport sux on weekends from here....let alone getting home!
Apparently this place is really expencive.. they charge like 12.50 for a vodka and redbull!
Jess...
You always pull out of the dinners.. YOU SUCK!
Circumstances beyond my control! Next month I won't even mention I am coming and Il turn up! Besides if I can get a car for Saturday night il be there.... just don't like my chances of dad handing me his keys.... its like his friggin baby that car!
Yeah it is a bit pricey but great atmosphere :(
I hope you can still make it :D
This place is sounding worse everytime someone tells us something about it. Dress shoes! What is this? 1990? I guess I better not turn up in my motorbike gear.
http://www.news.com.au/dailytelegraph/stor...5001021,00.html
Anyway, I'll still be there. I'm just depressed atm so I'm hanging shit on everything.
Unfortunately, I've been thinking the same thing, Adam. I heard about that whole public holiday fiasco last night on the news. As for the dress code (amongst other things), I don't get it either.
But I'm going there because of the people, not the venue...
FK.What a joke.But i'll still be there...Can you hear mariah carey in the background.
Dress Code
To provide an enjoyable experience for all, The Mean Fiddler enforces a smart dress code at all times. To ensure that you are permitted entry into The Mean Fiddler please follow the below dress regulations and be prepared to provide a valid form of identification (ie. CURRENT - drivers license, RTA proof of age or a legal passport).
Hats, thongs and singlets are not permitted at any time.
Dress regulations apply from 7pm Friday & Saturday nights.
Accepted
Collared shirt
Clean long dress pants
Polo shirts
Turtle neck jumpers
Ladies dress shorts
Dress shoes (females may wear hard soled sandals*)
* Ladies open toed shoes are permitted at own risk
Not Accepted
Singlets
T-shirts
Shorts
Tracksuit pants
Sports jerseys
Club colours
Headwear
Runners
Canvas shoes
Skate shoes
Sandals
Steel cap boots
Its not that bad. Looks like a pair of casual leather shoes should be fine. You don't need to wear a pair of shiny black dress shoes.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
