Item: EVOLUTION LANCER I/III
**** NOTE CAR HAS CD9A (Evo I) CHASSIS NUMBER****
ALL EVO 3 INTERIOR, EXTERIOR, FRONT LSD GEARBOX, DIFFS
COMPRESSION TESTED TO 9.0:1 7 BOLT CRANK EVO 3 ENGINE
ALL GENUINE EVO 3 PANELS
CAR HAS A LO1 BLUE COMPLIANCE PLATE RING ME OR PM ME FOR MORE DETAILS.
rego UUP41 (plates dont come with car)
Website:
Item Condition: mint
Reason for Selling:
i am starting to become over it
anyone interested please post
Price and Payment Conditions: $28,000 cash
considering trade for R32 GTR or R33 GTR
or maybe a 3.2lt 96 model 6 speed M3
or series 6 rx7
Extra Info:
:all standard evo features inc.
:reinforced chassis
:recaro seats
:momo steering wheel and gear knob
:digital climate control
:rear wiper
:power everything
:lsd diffs
:electric fold mirrors
:large front mount intercooler
:td05big 16g turbo
:extremly strong gearbox (rob barac has run 10s with standard box)
:alloy vented bonnet
:larger brakes
:intercooler water spray
:large oil cooler
:factory tilt slide sunroof (very rare only 5% had them)
car now has
:hks adjustable cams gears,
:full stainless 3 inch exhaust with polished double dump pipe
:walbro 500hp fuel pump
:bci pollished billet plug cover
:k&n panel air filter
:turbo smart boost control
:mine's ecu
:turbo xs hybrid blow off valve
:pro comp liquid filled boost gauge + carbon fibre cup
:pro comp air/fuel ratio gauge
:g4 coil over track spec suspension
:front and rear strut braces
:sparco racing harness
:odessey battery with dual battery system for stereo
:redarc smart solenoid
:sony cdx-ca900 head unit
:2 12in sony explode subs
: D class sony amp
:mtx thunder splits powered by sony xm amp
:nitrous express custom efi kit (wet kit) with 12lb carbon fibre bottle, purge kit with high performance solenoids and shark nozzle (worth over 3k)
:17inch ozzy racing rims
:new fedral 595 tyres
:new slotted rotors
:new ebc redstuff carbon ceramic race pads
:new npc high performance 3300lb custom clutch
:rebuilt gear box with new synchro's and synchro hubs
:heaps more shit i cant think of at the moment
featured in high performance imports mag issue 72
12.92 best et 110.48mph best speed, evo lancer with out nos
with nos even faster
Pictures: as seen in link below.
there are pics at the top of the link and at the bottom
Contact Details: Troy mob 0420 279 315
[email protected]
Edited by evo201
I am SO jealous -- best of luck with the swap man.
cheers mate
it is amazing how many people with r32 gtr's still think that they are an exclusive car
there is less then 30 genuine evo 1,2 or 3 lancers in the country
  • 4 weeks later...
bump it up, still available
now with new gear
just purchased
new SCM61 630HP turbo
new turbonetics wastegate
new turbonetics boost controller
new evo link plug and play computer with 3 bar map sensor
new club spec bolt in roll cage, fully padded
all still to be fitted
total of what has been spent on the car
car now has
:hks adjustable cams gears $800.
:full stainless 3 inch exhaust with polished double dump pipe $2000.
:walbro 500hp fuel pump $275 + install
:bci pollished billet plug cover $250.
:k&n panel air filter $110.
:turbo smart boost control $100.
:mine's ecu ***** will soon be replaced by link **** $500 second hand
:turbo xs blow off valve $350.
:pro comp liquid filled boost gauge + carbon fibre cup $200 + $120
:pro comp air/fuel ratio gauge $180.
:g4 coil over suspension $1700.00
:front and rear strut braces $200 each
:sparco racing harness $190.
:odessey battery with dual battery system for stereo $450.
:redarc smart solenoid $220.
:2 12in subs, d class sony amp, mtx thunder splits powered by sony xm amp $3000.
:nitrous express custom efi kit (wet kit) with 12lb carbon fibre bottle, purge kit with high performance solenoids and shark nozzle $3280.
:17inch ozzy racing rims $1500.
:new fedral 595 tyres $720.
:slotted disc rotors & ebc redstuff pads (semi race/quick street) $650.
:new npc high performance 3300lb custom clutch $1200
:rebuilt gear box with new synchro's and synchro hubs $2000
**** just purchased still to be fitted ****
:fully padded bolt in club spec roll cage (removable) $500.
:scm61 630hp turbo $1600
:evo link plug and play computer with 3 bar map sensor $1800.
:turbonetics evolution external waste gate $500
:turbonetics boost controller $140.
ouch that hurt, i have just totaled the cost of mods $24735.00
i had never done that before
i might have to review the price shows how good value this car really is
Edited by evo201
  • 3 weeks later...
  • 1 month later...
  • 3 months later...
  • 2 months later...
  • 5 months later...
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
