hi
recently i notice on cold start, there will be a puff, a very small one,not one you will see unless looking at the exhaust pipe.
No it only does this when cold, a puff, and that's it, unless you give it a boot fool when cold, and then maybe another puff.
Now the turbo has had a hard life, and i am wandering if it is that in anyway, or something starting to let go. It hasn't used any oil and i only noticed it since i put the synthetic stuff in it.
Commpression is good, no leak down yet. Car runs strong andso forht.
i wouldnt worry to much if its just on cold starts.
however, could also be turbo seals, valve steam seals or piston rings.
have been told best way to check is to, pull off your intercooler pipping and check for oil. If there is oil then it will be your turbo if not then its your rings.
also check your dipstick to make sure your levels are correct and you havint over filled.
can also get a compression and cylinder leakage test, that will let you know straight away.
Edited by HKS99
thanks guys.
Yeah i will pul the pipes off to have a look. I know when I tested the compretion 2 weeks ago it was all good. Will do a leak down and so forht.
Showed my old man, who is a bit of a car buff, and he reconed it was nothing, it could be th oil in it, as it is very thin, and synthetic, FUCHS oil.
I followed the car behind, and did not see any clods of smoke out of the car while running hot, but the oil is a bit high, propably 3-5 mmover full line. OOPPPSSS.
Didn't spot this before.
by a small puff, i mean you can't see it unless looking at the tail pipe.
And if you flog it dead cold, not a thing to do anyway, you will see a white/blue smoke behind for a second or so. Not a massive plume, just enough to notice.
I think it might be turbo seals leaking a bit. OK
STOP WARYING ABOUT IT. GOT IT. LOL.
i dont see how blue smoke in any case, big or small, isnt something to worry about.
if your valve stem seals are shot then it'll only get worse. make sure it is your turbo before writing off the stem seals.
oh well if it is the valve seals, loks like i get to build my 500HP motor. LOL.
Yeah at the momenti amnot really warried about it, it mainly started when i got the new thinner synthetic oil in it, will try different bra and type next chan,approx 1k away.
She has definetly not used any oil over the past 4K kliks, so so far it's all good.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
