Very nice and clean has an aggressive look to it but I have to recommend Car Toys to clean up the headlights, get rid of that 33 foggy headlight thing
Congrats on the purchase and Hi Tech dyno is a quality workshop John really knows skylines and how to treat them good luck with it
Thanks for the comments guys :3some:
Madaz: I'm very aware it's defectable, but fingers crossed as I try to stay out of trouble :spank:
TuffR32: Any idea for Car toys to do the headlight clean?
Hey lads, I don't know if your aware but there is a cleaning product out there from Maguires called "Plastic Polish"........ This product works really well, I have some if you really want to borrow it!!! i'd hate to think how much Car Toys is slugging you for prob a similar treatment.......LOL
Heard a story once about this 33 owner that went into a wrecker who had some clean as headlights, this person wanted to buy them because his were foggy!!! The wrecker said yeh no worries, give us yours and $300 and they are yours............ The wrecker guy turned around and started polishing the foggy ones......... 5-10 min later he puts them on the shelf for the same price as the good ones......LOL I found that to be rather amusing!
um this is the oldest thing with a skyline along with the clicking from the a/c lol. You can use tooth paste, i use brasso, also i think cut and polish works.......
I don't know about you dan but my air con dont click... must be a s1 owner common thing?
It's more like that, and the f**ken power windows.
Nah your just one of the lucky few....check out general maintenance or diy and search a/c you will learn lol
WOW I no the guy you bought it off, im a good friend of his. This is an exellent car that you have got, he took me for a drive a month ago and its great i wish i had it.
Have fun with it :-) Can i ask how much you paid for it in the end????
cheerz
Evans32: Yeah it was Simon I bought it off. Good guy, made the sale pretty easy. Price is between me and Simon, if he chooses to tell you, its up to him >_<
Tim: Absolutely! Im not sure when but we'll need to get together.
Haha, no I dont think I paid too much. I dont think I got a bargain either, I believe I just paid market price. ahh to hell with it.
$15k even is what I paid. I was happy with the price with what the car came with. I could've imported one for cheaper, but felt more comfortable buying locally.
yeah i think its a great price ive had mine little over 15 months and paid 21.5k with only pod front mount and some ghey manual boost controler with ive taken out for a turbotech one
ive just bought coilovers now will install them on sat. morning.
mine is the same year as yours but had about 123,000Km on the clock
so all in all i think you've found a good but because apart from new turbo you've pretty much got it all
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
