just wondering has anyone done it or is it possible to use a map sensor instead of a afm for a powerfc in a r33 gtst,
they are both 0-5volt sensors, voltage goes up as air flow increases in a afm and basically same in a map sensor,
i dont how the powerfc would respond to it since its all based on air flow meter tables. If so how would tuning be affected etc? i noticed paulr33 said he could use the rb26 powerfc to use either afm or map sensor.
It would just be a lot better and easier than trying hook up a afm to a turbo that needs a 3.5 inlet pipe into it :)
https://www.sau.com.au/forums/topic/163991-map-sensor-and-powerfc-for-r33-gtst/
