Hi guys,
just need a bit of verification from skylines addicts!! :) .
A friend of mine had a 260rs built 97'. He said that his engine output std is 233kw@wheels and mine was a 98' only pumps out abt 160kw@wheels before the tune and pwoer Fc upgrade.
I can live with a few kw differences between engine of the same kind but not like 50kw. Now i need you guys to verify wats the engine output fo a STD RB26 DETT? At crank and at wheels please. Thanks guys.
https://www.sau.com.au/forums/topic/164001-rb-26-dett/
160awkw is about right for a healthy 33 champ
Yea he claims the car is stock std. Everything is std. Actually the car was in quensland cant remeberthe company's name. But he bought it at 49k!! I looked at the car before i bought mine its black but too dear for me so i impoerted in the 260rs myself.
When he told me he was making 233kw i dropped my jaw and i thought that my engine is screwed somehow. But i thought about it if my engine is screwed why didnnt Ben from Racepace picked up the problem. So i told m friend to check his ECU first wheter is an aftermarket ones or not. Before he goes out and buy one.
https://www.sau.com.au/forums/topic/164001-rb-26-dett/#findComment-3040716
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
