Alpine TVE-T016 In dash colour TV in excellent condition. Fully motorised, goes in and out at the press of a button. Angle adjusts as well. Comes with Alpine TVE-T016 Mobile TV Tuner/Diversity Unit and aerials + leads. Works very well and has very good picture quality. Comes with Alpine remote. Only reason for sale is wanting to put money towards wheels or exhaust.
I have this hooked up to a PS2 at the moment and it works well.
Asking price - $400 + Postage, or could be used as part payment for set of 17 or 18's?
May also sell the pioneer mp3 head deck in the picture if someone offers me $150. It's 6 months old, comes with remote and perfect working condition.
Any questions or offers please PM me or sms (only) 0431 108 486
Steven.
Edited by mrclean86
What does this deck do, other than act as a monitor? Does it have any RMS output, or is it purely a screen?
I imagine you've been using your head unit to play music, and the PS2 through the monitor...
hey yeah that's what ive been doing. It's got an inbuilt speaker in the monitor but u can connect it to normal car stereo if you want.
The unit in the second pic is wat runs to the screen.. so you can run a gps system, dvd player, playstation/xbox, (ipod video.. if you can get a connection to rca's im not sure).
Any other questions feel free to ask:)
You can always just buy a slimline dvd player or something for 50bucks and buy an inverter from dicksmiths and connect it up to the monitor and it will play fine. Just needs a source to get the video from.
don't know how the tv stations are meant to work as i've never connected it up but it comes with aerials and leads to go in the antenna inputs so that's all i know im afraid.
But i know for a fact it plays dvd's and works with a ps2 you just need an inverter. Im sure it would play normal tv as well just never bothered to sus it out.
Came in my car when i bought it and no longer need it and as cool as it is to have dvd's playing while your driving id just prefer some engine mods.
the pictures don't do it justice it looks nice sitting in the dash and can be connected up to whatever you like.
thanks.
what are you after for an R33 - I have tons of parts here:
- new side skirts
- coilovers
- new cat converter
- 2 x hks ssq blow-off valves
- climate control unit
- stock steering wheel
- Unichip piggyback ECU
- stock rims and tyres
- air snorkel
- stock radiator
- stock engine fan
- O2 rush pod filter
- stock intercooler
- ROH Blade mags with tyres 114.5 x 5
- stock R34 turbo
- stock R34 auto radiator
Let me know if you are interested in a trade.
Andrew
just wondering...would you trade for greddy gauges and i pickup? gauges are water temp, oil temp, oil pressure(missing sender) and boost. theyre worth about $400+
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
