Hi all. I'm trying to program my mongoose M80G alarm to enable the turbo timer function. it states in the manual:
within 15sec , turn ignition on/off - amount of times for which option you want to change ( 13 times).
Now i did it 13 times with the drivers door open but i didnt get the 13 confirmation chirps. I tried it with the key turned to ignition 1 didnt work then the second ignition where all the lights (battery, airbag etc) lightup but still no chirps. Does the last on/off step have to been on the ignition or key turned off?
Now, anyone know how to do it properly? Does the turbo timer have to be disconnected now since its already been installed to enable the turbo timer function on the alarm?
Any help appreciated.
Edited by sumguy
https://www.sau.com.au/forums/topic/164149-programming-mongoose-m80g-alarm/
if the timer option is OFF the alarm will NOT arm with the car running. when you arm it press and HOLD the remote button - it will arm and chirp. tampering with the vehicle will shut it down.
  • 1 month later...
Can a new mongoose alarm use an old one together with it. As my car had one installed, but has been removed; except the immobilizer is still there. And thinking i might need a new one as the spare remote does not unlock or disengage immobilizer.
Just did a bit of a search...the one in my car is an MX40 Dual Immobilizer...
What is it worth? Keeping it and adding the siren or pull it out?
Also need to get second remote to work? (not the battery)
if it works and you cannot find the unit- use it. $200-$250 depending on who fits it. can add a siren to it and a few sensors if you like.
if you have the remote I can tell you how to program it.if not they are $60.
I would have to find the unit to add the sensors and siren anyway wouldn't it? I would give it a go, if it has instructions.
I have the remote, put a new battery in it push the button and watch as the LED lights up, and that's it.
Edited by 3340TH
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
