We recently had Powercruise visit Darwin. There were plenty of tough cars out and about. Here's a little vid of the shopping car:
Video doesnt really do it justice, my passenger was crapping himself.
Edited by RBNT
https://www.sau.com.au/forums/topic/164294-powercruise-darwin/
Brad, this was in 2wd, 2nd gear. I managed to stuff my new twin plate clutch, would have given 3rd a go. It made 489rwhp on 21psi. I have a tank of avgas in it now so I will put it back on the rollers and crank some more boost into it.
Love the minis Heath, my mate is putting a couple together atm.
Fully aware of how to drift bud, order yourself a Powercruise DVD and have a look. During the cruise sessions you are NOT allowed to drift, powerskids only ie, no sitting on the brake making a heap of smoke. All I was doing was plating it in 2nd and letting the motor do the rest of the work.
^^speaking from the number one rule breaker of SAU :pwned:
MADE!!!!!!! lol dont worry brad we still like you.
yeah least you get to have some fun with your shows. motorvation is a dismal event. love the fact the stagea can get the tyres spinning when rolling without to much effort. awesome.
Thanks for the nice comments guys and girls. Got a nos kit ready to go on, should get me around 650rwhp, which is stiiiilllll not enough to catch up to Brad! Damn your Jun powered trolley :pwned:
Jun powered "VOLVO" LOLOLO!!
well thats no fun :(
'sif the yanks know anything about powerskids and burnouts! Don't you guys still chock the front wheels in a burnout comp? I have always thought that was the main reason drifting took off so fast in seppo land.
Click the link and you will find out why powercruise has been the fastest growing motorsport enthusiast event in this country.
http://www.powercruise.net/
^^speaking from the number one rule breaker of SAU :(
if you need nitrous to get 650HP, you need to build your motor a little better
A real good friend just dynoed his r32 at 600HP. with no nitrous and N1 turbos
Dont know who you are buddy but i am pretty sure you dont know much about my car. It is built to take 1000hp. Not sure where your mate got his car dynoed but 600hp at the rears on n1's is pretty high. Do I need to mention my run was done on 21psi?
yeah, his N1s are maxed out, time to upgrade
ill be happy with my measley 400 on an rb25
but why are you using nitrious instead of a larger turbo?
I dont know about aussie
but NOS Is like 200 bucks a small bottle to build.
at that price its more economical to pay for a larger turbo to me.
But sitll, your number is impressive
what turbo was that on?
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
