Guest INASNT
Originally posted by RON-15H
just wondering i have just ordered a trust dual piller guage holder and i intend to use autometer guages are saying that they wont fit?
cause the jap size is 60mm
and the autometer size is 2.25" which is the same???
they dont mate up 100%, u will have to trim the gauge holder a bit.
Originally posted by INASNT
yes, ask meggala, 1 of those boost gauges was the cause of his blown engine
I believe you and your opinion on these forums means a lot i think and you know your stuff but are you basing your writing off an entire range on just one instance or is there more proof that they are crap.
I just want to know as i though that splitfire and autometer were in the same league and i havn't heard anything wrong with autometer.
i got my one form rampage in newcastle cost me $180 the spiltfire gauges u just haw to cut the top out very finely just a little bit at a time ever slowly till u get a it to fit to mch and it looks shit house u c the back ov the gauge
so yes u can fit the big spiltfire gauges in to the piler mounts and looks good
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
