Reason why i ask is because ive got one on my R33 and i recorded a 13.02 & 13.00 and everyone is telling me that my 33 cant do those kinda times and that it must be totally out.
Ive checked the speedo on the RSM and it seems fine. the speedo on the dash is wrong but the RSM is right.
Are they 100% acurate? or just total garbage and im really doing 14's or something ?
It even said 4.77 0-100 on a good launch.....
I have the older Apexi one, not the Blue screened one...
anyone have one of these and recorded it while at the strip to compare times ???
anyone have any ideas how to make sure they are accurate? (i dont have a drag strip available where i live)
https://www.sau.com.au/forums/topic/16467-rsm-are-they-acurate/
does yours have g-force sensor or just use wheel speed? With wheel speed only, anytime your wheels are spinning its inaccurate - think of how quickly the wheels can cover 400 m if they spinning, and how much less distance you'll actually have covered.
I used to have an AP22 which uses g-forcs to calcualte accurate figure. G-tech is similar, and I understand there is an add-on available for RSM to do the same.
They're not that accurate unless you get the G sensor, and still yet is a little off. It's not as good as going to the track and getting time slips there. That's where you can brag about your times and back it up solid.
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
