I have an R33 GTST with the factory plumb back BOV and a Pod filter.
Over the last 2 days I've noticed the BOV doesn't fire at all under gentle driving and only fires a little bit under harder accelleration.
Where the BOV usually triggered, instead I hear a fluttering sound I assume is caused by the excess pressure not released by the BOV going somewhere like back through the turbine.
I have not modified anything.
None of the vacuum leads are disconnected or obviously cracked or perished.
Is the factory BOV a serviceable item?
Is the factory BOV able to cope with 1 Bar of boost (I've been running 1 bar with a HKS 25/30 turbo since I bought the car 6 months ago) ?
Is it more likely to be the BOV or something else?
Is it the ECU that triggers the BOV?
will it damage anything if I drive it hard? - I assume lots of back pressure on the turbine can't be good.
cheers
Mike
https://www.sau.com.au/forums/topic/165211-stock-bov-not-working-properly/
take the bov off and have alook at the piston and see if u can push it up if not then maybe its ceased dunno if there a serviceable item but u would probably find one in the for sale section for cheap enough if ur boost pressure was to high ur bov would leak not stay shut and no ur ECU dont controll ur bov pressure opens it when ur throttle body closes
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
