Can anyone please tell me how to run the lines for my carbon canister? There was a paint tin size one in the car when I got it shoved in near where the oil filter is on the LHS of the engine bay, this was removed by a work shop a while ago.
I tracked down a standard size one with the bracket to mount on the front bar.
The markings on the top are : Fuel tank, VC and Purge on the top, and there is another fitting down the bottom.
There are two small diameter pipes that go from the plenum over the top of the coil cover. These are blocked off at the moment but which one goes where into the carbon canister? I think one goes into VC and the other in Purge, which leaves the fuel tank and the one down the bottom that needs to be connected somewhere.
Any help would be great.
Thanks
https://www.sau.com.au/forums/topic/165574-installing-carbon-canister/
On your picture:
1 - VC
2 - Purge
(ie they cross over, top goes to bottom, bottom goes to top) and the last hose (fuel tank) on my car just routes downwards.
Thanks mate, any ideas for the one off the bottom?
Ahh ok that clip on the bracket might be for the fuel tank one, I assume the fuel tank one just clips into this to hold it facing down.
Need to put it in, not worth a defect.
I am getting crap fuel economy again (was o2 sensor last time) so I am putting carbon canister back in and changing the coolant temp sensor. Hoping that it will fix the problem.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
