Hi all. Pulled out my slipping clutch this arvo. Did not know what clutch was in it but it is absolute crap! One day it is nice and firm,next day light as a feather!
Found that the rivets had broken out of the friction plate that hold on the fiberous material. Car has 181rwkw... Clutch type EXEDY EXTREME ORGANIC.
Think i will go clutch like my old car, with new one 3 puk brass button! Did'nt have a drama at all with that, copped a lot of abuse!
Overall i think they are very over rated! :santa:
https://www.sau.com.au/forums/topic/165652-exedy-clutches/
That's what happened to my last clutch (also exedy organic - different car though). Also had some cracks around the springs.
It did get treated like rubbish though and lasted a while, so I got another because I didn't know of any real alternatives at the time.
https://www.sau.com.au/forums/topic/165652-exedy-clutches/#findComment-3067975
They are good clutches.It all depends on what you want to do with your car,how much left leg work you want to do,and how much power it has to hold.
Stock would be much like the one you have there.Full faced but with a heavy duty button.
For 180-220rwkw i would recomend either a 8 puck as above "i have not seen these yet".5-puck,or 3 puck ceramic sprung/cushion button.They are easier on the leg for street not so much on/off feeling.And they will see you through track days well.
For 250-320rwk.Maybe a super single or twin plate???The twin is a bit harsh for street/city driving so i am told.So would be that kind of power.
Then you move into tripple plate etc.Cazy power cars.
Personally i use the 5puck ceramic sprung button and it has held out well.Though for the numerous events it has seen plus daily driving at arround 1.5yrs.It is allmost time to replace it.
Though others have differing opinions on what power they can hold.This is what i beleive they will comfortably hold.
https://www.sau.com.au/forums/topic/165652-exedy-clutches/#findComment-3070244
My Exedy Organic has so performed flawlessly, and it's seen 1.5 trackdays, about 15,000km and 6 months - maybe more (not sure.
How it looks today:
This is the bellhousing after 6 months - look Ma, not dust !
My pressure plate assembly is the same used for the brass puck clutch, rated at 70% higher clamping force than stock.
https://www.sau.com.au/forums/topic/165652-exedy-clutches/#findComment-3074804
just finished putting in a HD exedy clutch. feels real good and holds up through 2nd and 3rd no slip. I was thinking of getting a small (20thou) step machined into the flywheel ,they're suppposed to be flat, to give it a bit more clamping pressure but ran out of time.
Not sure of the clamping pressure but on installation the diaphragm spring caused the pressure plate to distort so that the bolts had to be tightened to get it to slip over the dowels..... So im guessing theres plenty there!!!!
Pedal is slightly heavier but not really noticable all in all pretty happy. I had a brass clutch in another car once and it ended up wearing the flywheel out, good for the track but everyday driving it sucked!
https://www.sau.com.au/forums/topic/165652-exedy-clutches/#findComment-3079487
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
